Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Filter pump running hot and water is not circulating. We have a 10 x 30 Intex inflatable pool. Also, pump keeps popping the circuit breaker
  • 640 Answers
If your pool filter and pump are running not and not circulating, it sounds like either your pump is not primed properly, you have an impeller jammed/or broken, or you have something clogging the hose to the return line that is causing pressure to build up. Check all three of these and bet you will find your problem.
Posted on Sep 08, 2010
My Intex 603M will only run for 5 min or less before it trips it own circuit breaker.?
That unit has a GFCI breaker installed. Those are made to prevent electrocution. IF there is ANY water leakage from the pump into the area that supplies voltage, the breaker will trip. Make sure that there are no damp areas inside the unit and make sure that you have all the wires that it connects to wired correctly and have ground connections.
Jun 24, 2016 | Intex Pool & Spa
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Dose not heat
check temp sensor
Jun 17, 2014 | Intex Pool & Spa
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
188 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
