Question about Pentair MINIMAX NT TSI IGNITER
Pentair Minimax Ignitor lockout fault - Pentair MINIMAX NT TSI IGNITER
    Top Expert:
  • Pentair Master
  • 8,487 Answers
Tried to run 3 x check gas ans ignitor
Posted on Oct 07, 2017
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
john224
  • 1378 Answers
SOURCE: new ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
  • 128 Answers
SOURCE: Pentair minimax nt just replaced ingnitor module
This means the air switch is bad.
Posted on Aug 23, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
Getting ERR message on my Pentair Minimax
make sure filters are clean then check to see if voltage on both sides of pressure switch if so check to see if voltage to ignitor if so ohm out ignitor should be about 78 ohm at 70 degrees if ok then see if safety circuit is ok then check to see if 24 volts to the gas valve brown wire and yellow wire
Jul 26, 2014 | Pentair Minimax NT Heater
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
New ignitor..still won't light
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair MINIMAX NT TSI IGNITER Logo
122 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
