Question about Jandy AQUALINK RS TELELINK KIT
My computer does not have any thing on it it is
My pool computer is bank it will not turn on seems like no power going to it.
  • 84 Answers
These Jandy PowerCenter's supply power to the Aqualink remotes and telelink. It may be bad. You can have them fixed reliably for much less than buying new. www.fixyourboard.com
Posted on Jun 11, 2010
Need to change my bank details to ANZ bank to pay my account
wouldn't it be more secure to talk with the banks face to face to do this as that would be the sensible thing to do
Jul 28, 2017 | Computers & Internet
When I turn on computer the gateway logo pops up then goes off and then it just keeps doing it over and over. what do I do?
I would need more information to give you a better idea of what may be going on. But from the limited information given, i would say it is probably a driver issue. What more than likely happened was, your computer automatically installed a updated driver for a hardware device on your laptop. This happens often is usually a headache for most users but a fairly easy fix.
1. Turn off your laptop where it is not restarting anymore and is completely off.
2. Turn on your laptop, then immediately press the F8 key repeatedly several times a second. You will be prompted by a new black screen with several options.
3. Choose the option that says : repair your computer
4. The computer will start a diagnosis of why your computer will not POST. Which means why it will not make it to the operating system.
5. If you still have the same issue, Do steps 1 & 2 again, then instead of choosing the option: Repair your computer, Choose the option: Last known good configuration.
6. If you still have the same issue, Do steps 1 & 2 again, then Choose the option: Repair your computer, then choose the option restore or recovery/ image recovery.
WARNING! IF YOU CHOOSE TO DO A RECOVERY/ IMAGE RECOVERY, YOU WILL LOSE EVERYTHING ON THE LAPTOP!
INCLUDING PROGRAMS, PICTURES, VIDEOS, MUSIC, DOCUMENTS ETC.
I STRONGLY RECOMMEND YOU HAVE A PROFESSIONAL GET BACK-UP OF YOUR FILES AND THEY WILL ALSO BE ABLE TO RECOVER YOUR COMPUTER TO FACTORY CONDITION.
Apr 04, 2014 | Gateway NE56R10u Laptop
No power when I turn my breakers on for my 1081 pool pump
MichaelUnwire the motor and turn the breaker on.
  • Check to make sure you have power coming out of the breaker.
  • If the breaker seems to be operating normally check the voltage at the motor when the breaker is on.
  • If there is voltage going to the motor then there is going to be a problem with the motor.
Is it the correct voltage going to the motor? If perhaps this is a 120v motor and you have just sent 230v to it you have damaged the motor.
Not sure other than that starting point.
Rod
US Parts Center
888-521-6183
Mar 03, 2013 | Pool & Spa
Turns on but won't move.
With these pool cleaners, the first thing you will want to check is for an obstruction in the drive shaft. Hair, leaves, and even cloth gets stuck sometimes and prevents movement. Make sure that you have sufficient water flow. Make sure that your impeller is not jammed. If none of these things seem to be wrong, it is probably going to be your electrical system.
Aug 28, 2010 | Smartpool Dolphin Robo - Kleen Above...
Pool pump won't turn on what is wrong
These Intex system's are not the highest quality in the world, and 3 years is a while for them to sit. If it was locked up, you should still be able to hear or feel the pump trying to do something so I would imagine you have a lose or corroded wire/connection. If you're decently handy you can eyeball check some of it, but no Internet answer can break down the whole thing
Intex does not appear to sell a replacement for the pump/motor itself, just all of the other parts, so it looks like you'd be stuck replacing the whole thing.
Jun 30, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
My pump is no longer working my pool water is starting to turn green, I shut down the power but I can't seem to open up the pool pump to clean the basket can you give me any suggestions?
First get some liquid chloriene in the pool start with about four gallons. Loosten the lid ring then turn the pump on and back off after a few seconds. If your trying to get the pump housing open do the same thing with the lock ring that holds it closed.
May 06, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My jandy pool control panel has gone dark as if it has no power. is there a fuse or something of that nature that i can check?
check the breaker that is marked rs in jandy service panel first.Then check the red terminal bar in the upper left corner of service panel. It may be unplugged or have loose or broken wires.then check the red terminal bar on the inside remote
Oct 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
106 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
