I have a 50" samsung DLP. On the left side approx 3" from the side there is a line of demarcation. On the right side the picture is great. On the left side the picture is washed out. Is the problem with the mirrors and can it be corrected?
  • 10,594 Answers
Please intimate model number of your Samsung 50 inch dlp tv to provide you helpful info.
Thanks.
Posted on Jun 05, 2010
  • 3 more comments
  • nalhorn Jun 05, 2010
    it is a samsung HL-R5078W
  • Shahid Electronics
    Shahid Electronics Jun 05, 2010
    Light tunnel need to be adjusted and adjustment screws would be located on light engine next to color wheel location.
    Click HERE to download service manual free copy that will help you to fix the issue.
    Download all 19 files and unzip it with Winrar software, it is available over internet if you need that, unzipping will give you pdf files of service manual that has all technical info about this tv.
    Thanks.
    There is technical new about light tunnel adjustment in pdf format. Let me know your email address to send it to you that will help you a lot.
    Thanks.
    Thank you. My email adress is nalhorn@gmail.com. On a scale of 1-10 what is the difficulty?
    Right, I just sent you technical info on your email address that will help you.
    I do not think difficulty level for technical person, you can say its 5 out of 10 scale if you are not enough experienced.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Black line
I just had this problem with my Samsung 50' DLP HLR5067WX/XAA. Fortunatly it was still under warranty with Best Buy, so they fixed it for me. They had to order a brand new light engine. (or where the mirrors are, if i'm not using the right terminalogy) He said the problem is with one of the mirrors that has slipped (or slipping because overtime the black line will get thicker and thicker). I hope i'm saying it right, but it was with a tiny mirror that was slipping. Hope it's under warranty. I've also had 1x component plug burn out on me, my HDMI port went to ****, and he's gotta come back out because when he made the repair, the picture was reflecting too high up and to the left. (MLB 2k7 for xbox 360 - scores on top of screen are about 1/4th cut off). He said is next trip back to my house would result in me getting a new TV, so can't wait for his arrival! good luck with your tv
Aug 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Hlp4663w color wheel
Check
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung rear projection tv have vertical black linens up and on tv
you have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulg all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
Jan 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
