Question about iLO 3200 32 in. LCD Television
Our TV suddenly stopped working and will not come back on
    President:
  • 1,099 Answers
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages.However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem and the only use in feeding the TV fuses will be to keep the fuse manufacturer in business!
Sometimes, a fuse will just die of old age or be zapped by a power surge that caused no damage to the rest of the TV. However, it must be an EXACT replacement (including slo-blow if that is what was there originally). Else, there could be safety issues (e.g., fire hazard or equipment damage from too large a current rating) or you could be chasing a non-existent problem (e.g., if the new fuse is not slo-blow and is blown by the degauss circuit inrush current but nothing is actually wrong).
If the fuse really blows absolutely instantly with no indication that the circuits are functioning (no high pitched horizontal deflection whine (if your dog hides under the couch whenever the TV is turned on, deflection is probably working).) then this points to a short somewhere quite near the AC power input. The most common places would be:
Degauss Posistor - very likely.
Horizontal output transistor.
Power supply regulator if there is one.
Power supply chopper (switchmode) transistor if there is one.
Diode(s) in main bridge
Main filter capacitor(s).
You should be able to eliminate these one by one.
Test the rectifiers individually or remove and retest the resistance.
If these test good, use an ohmmeter with the set unplugged to measure the horizontal output transistor. Even better to remove it and measure it.
C-E should be high in at least one direction.
B-E may be high or around 50 ohms but should not be near 0.
If any readings are under 5 ohms, the transistor is bad. The parts sources listed at the end of this document will have suitable replacements.
If the HOT tests bad, try powering the set first with your light bulb and if it just flashes once when the capacitor is charging, then put a fuse in and try it. The fuse should not blow with the transistor removed.
Of course, not much else will work either.
If it tests good, power the set without the transistor and see what happens. If the fuse does not blow, then with the good transistor (assuming it is not failing under load), it would mean that there is some problem with the driving circuits possibly or with the feedback from the voltages derived from the horizontal not regulating properly.
Look inside the TV and see if you can locate any other large power transistors in metal (TO3) cans or plastic (TOP3) cases. There may be a separate transistor that does the low voltage regulation or a separate regulator IC. Some TVs have a switchmode power supply that runs off a different transistor than the HOT. There is a chance that one of these may be bad. If it is a simple transistor, the same ohmmeter check should be performed.
If none of this proves fruitful, it may be time to try to locate a schematic.
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
But if otherwise your power supply board is died, It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck....
Posted on Jun 05, 2010
The sound on my TV has suddenly stopped working
check all wires are firmly in place, especially the scart lead, and just give them a little push to make sure, if that doesnt work, try unplugging your tv from the mains and wait 5 mins, plug it back in, wait another 5 mins, and turn on, if that doesnt work, contact the company's customer service line.
Mar 17, 2012 | Sharp Televison & Video
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
Tv suddenly stopped working
there is technical problem in your tv call and ask a service center to come n repair
Jun 21, 2009 | Televison & Video
TV suddenly stopped working; not will not power up at all.
it may have overheated
or it blew a internal fuse
if this is the case you may be covered under warranty. if warranty is expired contact
http://www.tacp.toshiba.com/customersupport/contact.asp
Apr 29, 2009 | Toshiba 26HL83 26 in. LCD HDTV
HDMI Port not WORKING.
Try unplugging the TV for about a minute and then plugging back in.
Mar 21, 2009 | Westinghouse SK-19H210S Television
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Xbox 360 sound stop working
It took me a long time to figure out but all I had to do is turn my TV all the way off and back on then it was fine.
May 01, 2008 | Microsoft Xbox 360 Console
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
iLO 3200 32 in. LCD Television Logo
191 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
