Question about Dell Dimension 3000 PC Desktop
I have baught a photo program from BB and your Geak Squad said I needed more memory and I gave him my info & he said PC3200,is that Centon 512MB PC3200?
I am Tonya Decker and need to know if PC3200 memory is the same as Centon 512MB PC3200.Thank you.You can E-mail me @ tdquarter@yahoo.com
  • Tonya Decker Apr 10, 2008
    Thank you to all that helped me,this is my first computer..I,m a farm girl so I didn't have a real interest in a computer till I had my kids.So you can emagine how behind I am in technology.Therefor I realy appreciate your help!Thanks again,T.D.
    Genius:
  • 1,027 Answers
PC3200 means it uses a front side bus of 400MHz.
not all ram at 3200 is compatible with all machines
some are single and some are dual channel.
crucial.com has a configuration utility that will show what the max ram the system will accept.
Posted on Apr 10, 2008
    Genius:
  • 1,226 Answers
Hello tonya,
PC3200 memory and Centon 512MB PC3200 if they both DDR400 its thesame.
that is absolutely the same.
melnavz
  • Emelio Navaja
    Emelio Navaja Apr 10, 2008
    Its my pleasure T.D, You can ask me anytime about computer. i am always here to answer. Good day to you. melnavz
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
I'm looking to upgrade the RAM in my father-in-law's computer (Compaq Presario SR1500NX desktop). All the "see what ram you need" searches on various websites that sell memory indicate PC2700 is...
This is the memory specs for the SR1500.
Presario SR1500NX Memory Specifications Standard Memory 256 MB (removable) Maximum Memory 2 GB Memory Expansion 2 sockets Memory Comments PC2700 DDR SDRAM DIMMs. CPU Type 2.0GHz AMD Sempron 3000+ Model Comments 333MHz FSB, VIA KM400A Chipset.
The PC2700 refers to the RAM speed, so you can use PC3200 which is faster RAM than PC2700, the PC3200 RAM should be more expensive not cheaper unless this supplier has stock he needs to unload.
You will not get any speed performance with the PC3200 RAM because the motherboard cannot make use of this faster RAM.
Dec 03, 2010 | HP Compaq Presario SR1500NX (PX786AA) PC...
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Adding More Memory
Reset the BIOS using the motherboard jumper before booting into Windows.
Jul 23, 2008 | ASUS P4S800D-X (610839122325) Motherboard
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Memory
That memory you have listed should work with your board. Matched memory should be bought inpairs. Check your manual at pg. 1-19. There is the QVL list of teaded memory
Hans a great day!
Mar 22, 2008 | ASUS P4S800D-X Motherboard
Dell Dimension 3000 PC Desktop Logo
51 people viewed this question
Alun Cox
