Question about D-Link AirPlus DI-524 Wireless Router
D-link error from broken upgrade
I was upgreading my router when the electric cable went loose and now i cant seem to get it to connect.i comes on and 2 light keeps blinking ,but cant conect to it through 192.168.0.1
Bought a used DI-524. All lights light without cables attached. Tried reset to no avail. Cannot reach default ip. Possibly firmware????
Posted on Jul 01, 2010
    Master:
  • 404 Answers
There should be a tiny hole in the back where you can fit a needle inside it, that will reset it to defaults.
Posted on Jun 05, 2010
WAN light keeps blinking on my Wireless N Home Router and I cannot access the internet although I can access the router config page. This started just yesterday and before that the WAN light used to be...
How old is the device? May be time for a new device? Has there been any electrical storms? Power surges? Tried different connecting cables? When you reset the device, hold reset for 30 secs., release, wait for selftest, unplug device for 30 secs., plug in, wait for selftest, connect with a Ethernet cable, reconfigure SSID and Security Key.
Apr 28, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
My Linksys WRT54GS ver. 6 Router continuously blinks
Try un-plugging all the cables from the router for 30 seconds, then re-connect them.
Hope this helps!
Feb 04, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Internet connection drops within 5 min after (re)booting Airport
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
Aug 26, 2009 | Apple AirPort Extreme Router
WRV54G Linksys router right out of box setup and for 5 min no prob then...hell broke loose neither computer had internet access(2 comps and an iTouch) connected via bypassing router and worked fine...
Do you have DSL or cable? Try resetting your router. Press the reset button on the back of the router and hold it it for about 5 seconds. When the router comes back up type in the router address: 192.168.1.1. If your ISP is using cable, make sure that you have DHCP enabled. If DSL, you will have to put in your username and password given to you by your ISP and you will have to enable PPPOE on your router.
Jun 11, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Can't connect to internet when router is connected.
You might try this:
1 power off or unplug your cable or DSL Modem.
2 Power off your router
3 waiti about 30 seconds,
4 plug in your cable/DSL modem
5 wait until the modem boots up (all lights except activity should be on)
6 power up your router.
Did that work?
Apr 05, 2009 | Belkin (F5D7230-4) Router (VVLZ253558)
My orange light keeps blinking..
Try to do a reset on the router. Hold down the button on the back of the router for 1 second. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 21, 2009 | Linksys Wireless-G WRT54G Router
Cannot reset or access configuration page.
The PC will detect a closed loop within the Network cable so forget that. Sorry but the router is bad if you cannot access it and the reset button does not help.
Have to get another 1
Nov 11, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
87 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
