Question about Kenwood KDC-315S
Whining problem on a 95 mustang gt convertible
When i have my stereo on, with or without the volume up, occasionally i get this whine that increases in pitch along with the engines rpms. you kick the kick panel and it will quit. i have checked for bare wires in this area and i can't find anything. it did it with the factory stereo as well as 2 different aftermarket stereos. does anyone have any ideas as to what it could be?
  • 18 Answers
This is a pretty common problem, and its from the can install an in-line noise filter (available at radio shack or anywhere sound systems are installed).... just follow the instructions on the package....the installation is painless also check your grounds make sure they are secure, and make sure if you have and power lines running to any amps they are not inter twined with any speaker wires.
Posted on Jul 09, 2010
97 Lincoln Continental whining noise when driving noise increases when pressing on gas also sometimes when starting the car it goes away once in awhile
that whine you are hearing is the transmissions torque converter , it is low on fluid , how long since you had auto tranny flushed , pull the tranny dipstick , fluid should be red or pink , if it is brown or even worse BLACK , your transmission is ready to fail
Apr 05, 2014 | Cars & Trucks
Engine making whining noise
There are a couple of things to check. If your power steering pump is low on fluid, or a bad bearing is in the Alternator, they will whine. The PCV valve or any hole in the Vacuum lines will whine as RPM is increased. Even having the Air filter box not fully seated will make a whining noise.
Now both automatic and manual transmissions can whine as RPM is increased. Check fluid for each.
Serpetine belt and pulleys-can make noise.
Sometimes you can shift into neutral at any speed and the engine rpm will drop almost instantly as the car rolls at speed. If the problem disappears as soon as the rpm drops, then an engine part probably is the reason.
Oct 11, 2013 | Ford Mustang Cars & Trucks
Ford mustang was making a whine/ rattling noise while doing 20-60 mph then after driving 20 minutes she died at a stop sign, would start up fine in park, but died when we tried to shift,what is wrong
Automatic or stick ?
If its an automatic, it could be something in the torque converter or transmission. The torque converter clutch could be stuck.
Dec 20, 2012 | 1989 Ford Mustang
Engine rattle while accelerating but stops while idle: Jeep Ch. 95
easy stuff. remove the belt and spin and wiggle the idlers
Jul 18, 2017 | 1995 Jeep Cherokee
Timing chain change
I do NOT believe that the timing chain needs to be replaced until the oil pressure-controlled tensioner is at its maximum runout. That can happen in a few thousand miles if you race the car - or can take 150,000 miles if you use it as a daily driver. The chain will whine loudly when it is no longer being held tight.
Oct 10, 2009 | 2007 Ford Mustang GT California Special...
Multiple audio noises even when mixer faders are down
100% raidiation problem!
it was wid my denon protech also,
see if earthing is correct for all gears,
try keeping an equidistance of 10"inches between each gadets
May 25, 2009 | Digidesign MBox 2 Mini (USB, includes...
Silverado 4.8 liter engine makes a whining noise.
check power steering pump .check fluid level.
May 03, 2009 | 2003 Chevrolet Silverado Ss
BMW M3 E46 Stereo whine
What you are hearing is ground loop interference. If you have an aftermarket headunit/amplifier this is a common occurrence. A ground loop isolator in line with the low level amplifier inputs should solve the problem. Otherwise, it may be a malfunction of the stock cd unit or amplifier. BMW used a balanced input on some of the stock amplifiers, which would make ground loop interference all but impossible.
Apr 18, 2009 | 2002 BMW M3
1995 Rodeo has a whine to the transmission, is this normal??
Be Very Careful If your hearing whines from transmission.
On Automatic Could Be Filter, Low ON Transmission Fluid Or Power converter(Pump) Going out.
On Standard Could be low on fluid or worn gears.
Occasionally transmissions are misdiagnosed for rear end noise.
Feb 15, 2009 | 1995 Isuzu Rodeo
Whine noise
Does occur in certain conditions? Like when the Air Conditioning is on? Check the a/c compressor if so.
Jun 02, 2017 | 2001 Ford Mustang
Kenwood KDC-315S Logo
85 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
