Question about Motorola Mobility RAZR V3
I cant get the back open
Need to open back for sims card is there a trick to this?
Look at the top of the phone, see the little indent, push that down with your finger nail and pull the back away from the phone
Posted on Apr 10, 2008
Transfer contcs from a blackberry curve9350 to apple 3gs
u cant transfer it directly but u can transfer them to outlook and when u connect ur iphone to the pc u can choose to sync the contacts with outlook.
good luck
Feb 14, 2013 | Apple iPhone 3G
How to change a sim card in an iphon 3gs
to remove the sim card this requires a very small tool or fine needle or fine piece of rigid wire and insert it into the ejection hole located near the sim card.
Hope this helps
Aug 21, 2012 | Apple iPhone 3GS Black (16 GB)
Error message no sim card installed despite sim being in place.
This is a simple fix. Just pop the sim card out and put it back in. Sometimes you only need to disconnect the sim totally to refresh the cellular connectivity.
For detailed guide on pulling out the iPhone sim card, CLICK HERE.
For more iPhone tips and tricks, see THIS LIST.
Apr 30, 2011 | Apple iPhone 3G
How do I install sim card
On the top of your device you will find the SIM tray. There, you'll see a little hole. If you have the SIM eject tool, insert its end firmly into the hole, until the SIM tray pops up (a paper clip would also do the trick, in case you miss the SIM eject tool). Remove the SIM tray, place your SIM card into it (aligning the angled corner), and carefully place the SIM tray (along with the SIM card) back to its place.
Hope it works for you.
If you happen to miss its user guide, feel free to download the generic user guide for all the iPhone versions, directly from Apple support
Regards, Carlos
Jun 08, 2010 | Apple iPhone 3G
Invalid sim
1. (easyer way) When I got my Blackberry, I had to put it in a couple of times for it to work.
2. Buy a new sim card.
If this does not work, then check to see if it is unlocked.
Feb 04, 2010 | RIM BlackBerry Curve 8310 Smartphone
Where to put the sim card
Open the back cover of the phone, remove the battery,slip the sim card into the slot designed for the sim card. Later, install the battery,put back cover. Turn power on. That's it.
Dec 31, 2009 | LG HD4000
Cant figure out how to open back of phone to put in new battery
First: you need to simply remove the back; then after you remove the back the battery will be there. If it wasnt removed simply remove the battery from the back of the phone without it getting wet. There might be some slight difculty doing this. What you have to do is ; slam the back of you're phone; on you're thigh if you have anyproblems. also place the sim card in behind the battery u will find the sim card slot; . Then place it in the slot facing up wards.
Thank You; :-* Hope it works!
May 02, 2009 | T-Mobile Sidekick II
How to insert sim card in iphone
The sim card goes into a slot that is on the top of the phone. Use a paperclip to take the plastic "tray" out of the phone, put the sim card in, then slide it back in.
Refer to this website for pictures . videos / detailed instructions:
http://www.iphoneincanada.ca/tips-tricks/how-to-iphone-sim-card-removal/
Dec 24, 2008 | Apple iPhone Smartphone
Sim card not reading
check putting sim card into other phone..
i think in ur nguage the sim port has not fitted properly ... i think somebody opened the set before while refitting the things he didnt fitted the simport correctly .. sim port is in mis contact .. if you r good at opening set then it s a simple pronlem u only can fix it... just abpve the sim port the circuit board is not in contact with that so just opened it & refit it..
otherwise if u r afraid then visit technician...
Feb 11, 2008 | Alcatel One Touch C750 Cellular Phone
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
