Clothes come out with black spots. shows most on courners shuch as collar tips. Have checked drum but cannot find anything that would cause this problem.
  • 4,070 Answers
Try taking a narrow strip of cloth and with a back and forth motion pull it under the agitator to see if it gets the black on it. I suspect the transmission is leaking oil from a seal. Post your model number for diagrams and more information.
Posted on Jun 05, 2010
Very loud noise when spinning. also the white clothes came out with black spots. thanks
THE DRUM BEARING HAS GONE THE SPOTTING IS FROM THE OIL IN THE BEARING .IF YOU TURN THE DRUM WITH YOUR HAND IT WILL FEEL LIKE IT IS RUNNING OVER A COBBLED STREET
BUY A NEW WASHER
May 18, 2010 | Zanussi FJS1225W Front Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Black, tar-like spots on some clothes after wash
Hi
Its probably coming from the outer drum of your machine. That's what holds the water. Your inner drum, what you see, is full of holes and allows the water to pass through in the drum and wash the clothes. that outer drum gets crud in it which then passes through the holes onto your clothes. the easiest way to get rid of it is to get a product called "affresh" from W mart or the big Hardware chains and follow the directions. Good Luck
Dec 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
Dark spots on clothes coming out of dryer; clothes clean when cycle started
could be some u left in one your shirt are pant that fell out in dyrer an caugth between the drum seal
Feb 27, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
Random red stains appearing on clothes. Aeg Lavamat 50430
possible you have some red clothing in the gap between the tub and drum - there is nothing in the machine to cause red stains
to check, remove rear half of cabinet, remove heater (held by 1 10mm nut which just loosen and prize out heater) you can then see into the gap between tub and drum. shine in a torch and rotate drum by hand to see if you can spot anything. disconnect from mains first
Jul 23, 2008 | Washing Machines
Stains on clothes
yeah if the seal has gone even slightly then it will send grease out 1 way to check if the bearings are on there way out is pull the washer out take the back panel off and look in to see if there are any green spots on the back off the washer if there is then there on there way out another way is to place your palm on the front of washer place your fingers into the drum and pull your fingers up if there is movement then there going m8
Feb 09, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
