Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
Toshiba 46HM94 This TV have good sound,OSD ok, Menu shows up but I cannot get a picture from any of the inputs or tuners, I changed the back AV board, but the problem still exists. Thanking you in advance, Godfrey Burrows Last Chance Electronics
  • Teriya Jun 03, 2008
    Several problems occurred after connecting a Nintendo video game. Initial problems involved response to the cable and TV remote control and response to TV panel controls. After pressing the reset button, and unplugging the TV in an attempt to reset the TV, the problems deteriorated to no picture. The current problem is a green and white looking test pattern, and no picture. Audio comes through OK, but without volume bars. I thought the problem was the DLP lamp, but a replacement bulb didn't make a difference.
  • Toshiba Master
  • 8,617 Answers
The lamp has to be lit for the OSD to be present. the video processor is likely where the problem lies. I would suggest one of the following circuits SD Ram Circuit, Scaler input and or Capture circuittry and quite possibly the light engine itself all though the light engine would be very last on the list.
Posted on Apr 10, 2008
Sony tv osd ok but no picture
Check whether it is in AV mode. If not, check and replace its tuner.
Mar 31, 2013 | Televison & Video
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE CAN SEE PICTURE BUT IS VERY SNOWY I TRIED ALL INPUTS WITH CABLE DVD AND A GAME SYSTEM BUT NOTHING CHANGES AND THE WIERD PART IS WHEN I HIT THE MENU...
The OSD comes from a different area---if on all inputs it is on a board that processes all signal in the set--tuner,AV etc
You might want to Google the model number with "parts" to come up with a list of the boards and prices if possible for them.
Dec 04, 2012 | Toshiba Televison & Video
My JVC AV-32432 tv unresponsive
Can you switch between tuner and inputs? If not then you may have a number of problem i.e;input selector or controller i.c. If you can switch to tuner(cable) and do not get picture then you may want to check your tv cable connection at the back and along the line (splitters) or your tuner may be defective
Nov 17, 2009 | JVC AV-32432 32" TV
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Hitachi snowy screen and noisy
you have broken solder connections inside the tuner, you`ll need a tech as it is soldered in and once removed the board inside will have to be re-soldered. An alternative would be to use the AV outputs of your cable box or vcr to the AV input of your tv, this bypasses the tuner circuit, you will of course have to go into the tv`s menu and switch to AV 1 or AV 2 whichever input you use, good luck& Happy Holidays
Nov 29, 2007 | Televison & Video
61g9uxc Toshiba Rear Projection Convergence Problem
ronniezay,
Don't replace the convergence board, but take it in and have the convergence amps replaced. That unit takes two stk392-110 IC's and are fairly inexpensive compared to replacing the entire module. In fact, ask to have them replaced with a more reliable stk392-150's...
Bill
Nov 05, 2007 | Toshiba 61HX70 61" Rear Projection...
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
B/w picture on all av inputs internal tuner from av box colour picture from internal tuner via scarts to video recorder tv on screen menus in colour teletext via internal tuner av box.
sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Aug 13, 2006 | LG MZ-42PZ14 42 in. Plasma Television
Picture is snowy on every channel. I hooked up my playstation and set it to the correct channel but the screen display is the same. I tried using the menu and the menu comes up just fine. The menu goes on...
If one tv looks good and another one dosent look good or operate correctly then we know for sure that the problem is not the antenna. Now the menu comes up ok because the menu is injected after the tuner into the video curcuit from a osd or microprocessor. sounds like you could have a defective tuner or antenna block assy.
Mar 27, 2006 | Toshiba 42H83 42" Rear Projection...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
