Question about Brother SX-4000 Typewriter
Carriage Return Inconsistency
I have an Underwood World's Fair Model typewriter.  Recently, when I use the carriage return lever, the spacings are inconsistent--sometimes lines are close together, sometimes spaced a little more than single.  It is noticeable, and wondering if there is a simple solution.
    Novelist:
  • 116 Answers
It has been a while since I have seen a #5 Underwood. I think I still have one hidden in the attic that the wife thinks was thrown out long ago :).
The carriage return is done by the lever that pushes a pawl. The pawl engages in the ratchet teeth on the LH end of the platen. If the typewriter has the half-space feature, then it has to roll the platen two clicks (teeth) for a line space. The problems were usually in two places when this didn't happen correctly. The first is that the bushings on the platen were dry and needed oiling. The second was the follow-up roller is not clicking into the ratchet tooth and keeping it latched in the proper position. Because the platen doesn't roll far enough, or is free enough, the roller stops on top of a tooth instead of clicking into the space between the teeth. This can be caused by dry platen bushings, sticky follow up roller mechanism, or weak follow up roller spring. If you roll the typewriter on its back with the carriage all the way to the left, you should be able to pull the carriage return and watch the follow up roller action from underneath (you may need a flashlight). A light weight oil (Marvel Mystery or a sewing machine oil or Triflow) will be suffiecient to fix it usually. Put a few drops in the bushing where the steel platen shaft goes thru the end of the carrier and a few drops around where the mechanism that attaches the follow up roller to the end of the carriage. Roll the platen back and forth to work it in then slide the carriage to the right and do the shaft on the other end and work it again. Hopefully that will take care of it. If it doesn't, then the spring will have to be tightened by removing a loop. Depending on your mechanical ability and tools, that can be an easy or difficult job.
I didn't mean to write a book on the subject. I worked on mechanical typewriters years ago and hated to see them go to the wayside. I usually don't do this, but if I can be of anymore help, email me :cautionflag1956 at yahoo
Hope this helps
Posted on Jun 13, 2010
How to unlock electric type writer?
Christine: According to VintageTypewritterShoppe.com: "Underwood portables have a simple carriage catch on the left side right below the carriage. Move the carriage to the right a few inches to disengage. Remington portables have two systems. Early portables require the sliding out of the platen shaft/knob on the right end of the carriage. The lock lever is located on the left end of the carriage and is spooned against the left side carriage release lever. Newer Remington's(Model 5/Streamliner/Deluxe) have a small lever on the left end of the carriage located in the same spot as the earlier models. There is a little ball on top of the lever. Push the lever to the rear to disengage the lock."
May 18, 2015 | Office Equipment & Supplies
Carriage wont move on underwood 565 typewriter
Belt is slipping or broken..When it sits for awhile the belt stretches.
Dec 17, 2012 | Underwood 1980s 565 Cr Electric Portable...
On my Underwood Typewriter 18 the platen will not move to a new line when the lever is moved
Be sure that the line space lever isn't in 0 space, then try a little WD40 on the mechinism at the L. end of the platen,
DickyO
Aug 04, 2012 | Office Equipment & Supplies
Cannot unlock the carriage
There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
Oct 29, 2011 | Olivetti Lettera 25 Typewriter
Unable to adjust spacing when typing on 5A DX2600.How to fix?
What is the make and model? Usually a lever on the left side or right side of the paper roller (platen) with numbers or marks. If it is electronic, then a slide button on the keyboard.
Apr 12, 2009 | Office Equipment & Supplies
Was the carriage return ever on the right?
I have worked on typewriters fo 20+ years.
The only typ's I know of that had the return on the right hand side are all the manual typ's
Feb 19, 2009 | Brother ML-500 Typewriter
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
How do you unlock a locked carriage?
The solution is not right--there is a carriage return release lever on the far right of the typewriter, that engages a notch on the underside of the roller/carriage return--push it forward to release the lever and you are in business--it has a spoon shaped end and its on the right side
Jan 24, 2006 | Olivetti Lettera 35 L Typewriter
Brother SX-4000 Typewriter Logo
195 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
