Hi, I have a Goldair oil column heater which is a
Goldair oil column Heater
Hi, I have a Goldair oil column heater which is a few years old, it has 13 columns and two power switches and a rotating dial.
The heater was covered with a towel right where it shouldn't. It has a sticker saying not to cover, it has probably overheated and damaged something. Could it be just a fuse or a small part that I can replace or will it have caused major damage?
Regards
Paul
  • paul_algar Jun 05, 2010
    Thanks for the reply. I thought that might be the case. I will pull it apart today and see if I can see anything and repost if I get stuck.
    Cheers
    Paul
  • paul_algar Jun 06, 2010
    I now have it apart it seems very basic but I can't see any damage. The cable comes in, the positive and neutral go to a choc block and the earth to a seperate metal frame. From the frame the earth goes to the base of the heater, neutral goes to the power switches (named I & II for full power or half power)and another wire to the base of the heater. Positive goes to the dial then to the switches. A Black and white wire come from the middle of the switches to the base of the heater. The base of the heater compises of a large hexagonal fitting with four wire inputs including the earth wire.
    Could the fuse-able link be a part of this setup?
    If you can shed any light on what could have failed for me I would be very greatful.
    Regards
    Paul
  • 146 Answers
Im sure it has a fuse-able link that will melt when the temp gets to high. it is a safety option
Posted on Jun 05, 2010
  • mopar440man Jun 06, 2010
    if you are able to get your hands on a multi meter or a contanuity tester. all you need to do is go acrossed the switches and limits to see if you have contanuity. or you can jump out one at a time with a wire. not recommended to leave jumped out if you get it working recommend replacing the part. any my questions just ask
Internal 1/2 psi propane regulator is not passing gas thru so that heater wont light. Are there recalls? Where can I buy a replacement part? Heater is 2 years old, never lit.
What's the pressure to the heater? It should be a minimum of 11 to 13 water column inches. Also, make sure that your heater is in fact a propane fueled heater. Don't go by whats on the box it came in. Look at the manufacturer's tag(s) on the heater. It may be a Natural Gas unit instead of Propane unit. I've seen this happen before. In which case it won't work and can not be converted.
Feb 02, 2011 | Dyna-Glo D-E37 Wall Mounted Panel Heater
1990 taurus steps to replacing heater core
Heater Core REMOVAL & INSTALLATION NOTE: Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician. CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. NOTE: When removing the instrument panel, it may be beneficial to have a friend or assistant help you. Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the instrument panel on 1986-89 vehicles as follows:
    1. Remove the four screws retaining the steering column opening cover, then remove the cover.
    2. Remove the sound insulator under the glove compartment by removing the two push nuts securing the insulator to the studs on the climate control case.
    3. Remove the steering column trim shrouds, then tag and disengage all electrical connections from the steering column switches.
    4. Remove the four screws at the steering column bracket to remove the steering column.
    5. Remove the screws retaining the lower left and radio finish panels, then remove the panels by snapping them out.
    6. Remove the cluster opening finish panel retaining screws. On Taurus remove the jam nut behind the headlight switch and the screw behind the clock or clock cover. Remove the finish panel by rocking the upper edge toward the driver.
    7. Disconnect the speedometer cable by reaching up under the instrument panel and pressing on the flat surface of the plastic connector. The panel can be removed with the cluster installed.
    8. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    9. Using the steering column, cluster and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables and the radio antenna cable.
    10. Tag and disengage all underhood electrical connectors of the main wire loom. Disengage the rubber grommet from the dash panel and push the wire and connectors into the instrument panel area.
    11. Remove the right and left speaker opening covers by snapping them out.
    12. Remove the two lower instrument panel-to-cowl side retaining screws from the right and left side. Remove the instrument panel brace retaining screw from under the radio area. On Sable, remove the defroster grille by snapping it out.
    13. Remove the three instrument panel upper retaining screws, then remove the instrument panel.
  3. Remove the instrument panel on 1990-95 vehicles as follows:
    1. Position the front wheels in the straight-ahead position.
    2. Disconnect the positive battery cable.
    3. Remove the ignition lock cylinder and, if equipped, remove the tilt lever.
    4. Remove the steering column trim shrouds. Tag and disengage all electrical connections from the steering column switches.
    5. Remove the four bolts and opening cover, and the two bolts and reinforcement from under the steering column.
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column. NOTE: Do not rotate the steering column shaft.
    7. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    8. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    9. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    10. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    11. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    12. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    13. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    14. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    15. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  4. Drain the coolant from the radiator.
  5. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  6. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  7. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  8. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  9. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  10. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case. To install:
  11. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  12. Position the heater case access cover on the case, then install the four retaining screws.
  13. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  14. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  15. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  16. Install the instrument panel shake brace and screw to the heater case.
  17. Install the instrument panel by reversing the removal procedure.
  18. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  19. Fill the radiator and bleed the cooling system.
  20. Connect the negative battery cable and check the system for proper operation. Fig. 1: Location of the vacuum source line 86876016.gif
    Fig. 2: Heater core cover location 86876017.gif
Jan 30, 2011 | 1990 Ford Taurus
How do i fix the heater core on my ford taurus 1995
Remove heater/evaporator case. Remove vacuum source line from heater core tube seal. Remove seal from heater core tubes.
Remove heater core access cover screws. Remove access cover and seal from heater/evaporator case. Lift heater core and case seals out of heater/evaporator case.
Installation
If installing new heater core, transfer case seals to new core. Install heater core and seals into heater/evaporator case. Install heater core access cover on case. Install seal on heater core tubes. To complete installation, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
HEATER/EVAPORATOR CASE
Removal
  • Disconnect negative battery cable. Drain coolant from radiator. Gently pull instrument panel away from right side of dash panel.
  • Discharge A/C system using approved refrigerant recovery/recycling equipment. Disconnect heater hoses from heater core. Plug heater core tubes or drain coolant by blowing coolant from heater core using low pressure compressed air. Disconnect vacuum supply hose from inside engine compartment.
  • Disconnect A/C lines from evaporator core. Plug A/C lines and evaporator core tubes. Remove instrument panel assembly brace to evaporator case bracket screw. Remove assembly brace.
  • Remove floor register and rear floor duct from bottom of heater/evaporator case. Remove nuts securing heater/evaporator case to firewall. Remove 2 screws securing support brackets to cowl top panel. Carefully pull heater/evaporator case away from firewall. Remove heater/evaporator case.
  • To install, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
INSTRUMENT PANEL
Removal & Installation
  • Position front wheels in straight-ahead position. Disable air bag system. See AIR BAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT section. Disconnect negative battery cable. Remove steering column trim shrouds.
  • Disconnect all electrical connections from steering column switches. Remove cover from under steering column. Remove 4 bolts and reinforcement from under steering column. Disconnect parking brake release control motor from parking brake and ignition switch connector.
  • Disengage insulator retainer. Remove insulator. Remove 4 nuts and reinforcement below steering column. Remove 4 nuts securing steering column to instrument panel and lower column to front seat. Disconnect PRNDL cable (A/T models).
  • Ensure ignition switch is locked to prevent steering column from turning. Remove 4 instrument cluster retaining screws. Disconnect speed control cable and vehicle speed sensor (if equipped). Disconnect electrical connectors and remove instrument cluster. At steering column opening, remove one bolt securing instrument panel to brace. Remove one instrument panel brace bolt (below radio area).
  • Remove sound insulator under glove box by removing 2 push nuts securing insulator to studs on climate control case. Remove glove box door and compartment. Remove air cleaner housing, battery and battery tray. Disconnect wires of main wire loom in engine compartment. Disengage rubber grommet from firewall. Feed wiring into passenger compartment through hole in firewall.
  • Remove right and left kick panels. Disconnect wires from instrument panel at right and left kick panel sides. Remove screws on left and right sides of instrument panel.
  • Pull up to unsnap right and left speaker opening covers. Remove speaker covers. Working through steering column and glove box openings, reach under instrument panel and disconnect electrical connectors, vacuum hoses, A/C-heater control panel cables, and radio antenna cable.
  • Support instrument panel. Remove 3 screws attaching top of instrument panel to cowl top. Disconnect remaining wires. Remove instrument panel. To install instrument panel, reverse removal procedure.
Hope this helps...
Jan 17, 2011 | 1995 Ford Taurus
How to remove a heator core from a 2001 dodge caravan? do you have to take the dash out? or just the bottom pannel.
The 2001 Dodge caravan has 2 heater cores - front (the main one), and the rear. Removal of the
rear heater core is a whole different procedure than the front.
Front Heater Core - Removal and Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Align the wheels in the straight-ahead position.
  3. Disconnect the negative battery cable.
    CAUTION Before working around the steering wheel or the instrument panel all 2 minutes to pass to allow the air bag module to discharge.
  4. Drain the cooling system into a clean container for reuse.
  5. Remove the steering column, by removing or disconnect the following:
    Lower left side steering column cover Parking brake release cable from the parking brake lever 10 steering column cover liner-to-instrument panel bolts and the cover liner
  6. Rotate the key to the LOCK position; then, rotate the steering wheel to the LOCKED position.
    Gear selector cable and its mounting bracket as an assembly from the upper steering column mounting bracket 2 instrument cluster trim bezel-to-instrument panel screws, retaining clips and bezel 2 steering column shroud-to-steering column screws and the shroud Steering column-to-intermediate steering shaft coupler
  7. Loosen but do not remove the 2 lower steering column mounting bracket nuts/washers.
    2 upper steering column mounting bracket nuts/washers Steering column assembly from the vehicle
  8. Remove or disconnect the following:
    Instrument panel-to-chassis harness interconnect and bracket Lower silencer boot, at the base of the steering shaft
  9. Working in the engine compartment, pinch off the heater hoses.
    Heater core cover. Position some towels under the heater core hoses. Heater core plate and the hoses
  10. Depress the heater core retaining clips.
  11. Lift the accelerator pedal and slide the heater core past it.
  12. Depress the brake pedal and remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the steering column assembly
    Fig. View of the interconnect and bracket
    Fig. View of the front heater core assembly
To install:
  1. Depress the brake pedal and install the heater core into the heater/air conditioning housing assembly.
  2. Lift the accelerator pedal and slide the heater core past it.
  3. Install or connect the following:
    Heater hoses (using new O-rings) and the heater core plate Heater core cover Heater hoses clamps, working in the engine compartment Lower silencer boot at the base of the steering shaft Instrument panel-to-chassis harness interconnect and bracket
  4. Install the steering column assembly by installing or connect the following:
    Steering column assembly, carefully into the vehicle. 2 upper and 2 lower steering column mounting bracket nuts/washers. Torque the nuts to 105 inch lbs. (12 Nm). Steering column-to-intermediate steering shaft coupler and tighten the pinch bolt to 21 ft. lbs. (28 Nm) 2 steering column shroud and the shroud-to-steering column screws Bezel, the retaining clips and the 2 instrument cluster trim bezel-to-instrument panel screws Gear selector cable and its mounting bracket as an assembly to the upper steering column mounting bracket 10 steering column cover liner and the cover liner-to-instrument panel bolts Parking brake release cable to the parking brake lever Lower left side steering column cover. Lower left side steering column cover
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jan 02, 2011 | 2001 Dodge Caravan
Where is the heater core located
Dec 19, 2010 | 1987 Ford Taurus
There is coolant leaking on the passenger side underneath of the car and rear of engine. It doesn't seem to be the lower hose and both the rad and thermostat are new and appear to be dry. I suspect the...
agree, heater core. see procedure below
  1. Disconnect the negative battery cable and disable the SRS system (if equipped.)
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Properly drain the cooling system.
  2. Disconnect and plug the heater hoses at the firewall.
  3. Disconnect the heater valve control cable.
  4. Remove the heater unit attaching nut on the firewall.
  5. Remove the dashboard as follows:
    1. Remove the center panel.
    2. Disconnect the wire connectors at the fuse box.
    3. Disconnect the sunroof switch connector, if equipped.
    4. Disconnect the ground cable at the right of the steering column and the power mirror switch wire connector.
    5. Remove the side air vent knob and face plate.
    6. Remove the screws attaching the air vent control lever.
    7. Remove the center panel, radio and heater control head.
    8. Remove the gauge upper panel (4-door) or instrument panel (3-door).
    9. Disconnect the speedometer cable.
    10. Remove the center upper lid.
    11. Remove the side defroster garnishes on both ends of the dash.
    12. Lower the steering column.
    13. Remove the dashboard mounting bolts.
    14. Lift and remove the dashboard assembly.
  6. Remove the heater duct.
Fig. Fig. 1: Removing the heater duct assembly
  1. Remove the steering column bracket and duct assembly.
  2. Remove the heater assembly mounting bolts.
  3. Remove the heater assembly and remove the heater core.
Fig. Fig. 2: Removing the heater case assembly
Fig. Fig. 3: Removing the heater core from the heater case
To install:
  1. Install the heater core into the heater unit.
  2. Install the heater assembly and the attaching bolts.
  3. Install the heater duct and steering column bracket.
  4. Install the dashboard assembly. Tighten the mounting bolts until just snug.
  5. Raise and attach the steering column.
  6. Install the center upper panel.
  7. Connect the speedometer cable and install the instrument gauge assembly.
  8. Install the control head, radio and center panel.
  9. Install the side vent and face plate.
  10. Connect the ground cable at the right of the steering column and the power mirror switch wire connector.
  11. Connect the sunroof switch connector, if equipped.
  12. Connect wire connectors at fuse panel.
  13. Install the heater unit attaching nut on the firewall.
  14. Connect the heater valve control cable.
  15. Connect the heater hoses at the firewall.
  16. Connect the negative battery cable.
  17. Fill, bleed and leak check the cooling system.
Oct 05, 2010 | 1991 Honda Civic
I have an oil column heater about two years old, this year it is emitting an adour, is this normal , does the oil get old?
You need to give this heater a good clean with a mild detergent and cloth with it unplugged let it dry for a few hours then try it again. The oil is sealed inside inturn you can't smell this unless it's leaking.
Cheers
May 30, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Heater core
18901fc.gifHere is an exploded view of the heating/air conditioning blower box. This contraption is located on the passengerside under the dash. I've changed heater cores on other cars but never worked on a caravan so not sure how difficult it'll be. You may need to remove a few cover panels to access this and the heater core #22 is located behind the distribution box #6 containing parts 7-18 and hopefully comes off as a unit. I wouldn't want to put it back together just looking at the pic. You may just need to remove the heater tube cover #4 to access the connections and slide out the core.....NAH couldn't be that simple!!! Hope this was of some help. Good luck.
Oct 18, 2008 | 2000 Dodge Caravan
How to replace heater core 93 honda del sol
Heater Core Honda Civic/CRX/del Sol 1984-1995 Repair Guide REMOVAL&INSTALLATION
See Figures 1, 2 and 3
0900c15280061a21.jpgFig. 1: Removing the heater duct assembly
0900c15280061a22.jpgFig. 2: Removing the heater case assembly 0900c15280061a23.jpgFig. 3: Removing the heater core from the heater caseTo install:
Sep 01, 2008 | 1996 Honda Accord
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Heating & Cooling Logo
398 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
