Flickering red light
On my secon day of use of the HTS i was listening to a cd when all the sudden it turned off I unplugged it and pulged it back in and saw a red light flicker once on the standby light I tried turning it on but nothing then I kept trying it on diffrent sockets and the same thing it just flickered once as soon as i plugged it in and thats all it does . the only time I see the red light flicker is as soon as I plug it in
  • 4,234 Answers
If this is a new unit, return it for an exchange. There is a problem with the output amp section. This should be under warranty, request an exchange rather than a repair.
Dan
Posted on Apr 10, 2008
My Phillips HTS-3565 system will not come on what can be wrong?
May be the power supply section is Burnt
show it to a technician
Nov 24, 2014 | Audio Players & Recorders
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Hi, I have Philips HTS 3181, While running Audio CD, power suddenly went off and power came back...DVD Drive is not opening, please help
Hello,there is a chance that the brain(microprocessor) is confused and needs to be reset.Unplug the power to the unit for approximately 30 minutes and then plug it back in.Hopefully this resets the unit and it will respond to the open request.
Jan 09, 2011 | Philips HTS3500S System
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
TV will not turn on
the exact same thing happened to me but there is no red light when the TV is plugged sould i replace it?
Apr 17, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
Unit is behaving oddly
there is probly a short in the wiring some were
Jun 12, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
171 people viewed this question
 Grubhead
Grubhead
