Question about Toshiba Office Equipment & Supplies
I have a Canon Pixma ip4500 installed as a local printer on a PC desktop(O/S Win XP Pro 32 bit) wich is shared on a wireless network. I have added a new laptop (Toshiba Sat Pro L500 64 bit) to the network. No problems seeing the network or printer, but when I try to use printer on laptop it asks for a 64bit driver. I have downloaded and installed new drivers and it still will not load printer. (installing printer on laptop and it works just fine so a driver is there) Any suggestions?
  • maclas Jun 06, 2010
    Thanks, Every bit of info helps. I check out the print servers
    Maclas
  • Toshiba Master
  • 3,866 Answers
Problem is the 64 bit driver running in conjunction with a 32 bit driver on a shared resource is just not going to cut the cheese. You going to have to decide weather witch computer your going to print from or get a print server to do that communications to and from the both computers.
But to share a 32 but over a 64 bit over a network segment is just not going to cut it. Would suggest all 32 but systems or all 64 bit systems or print server.
thanks hope this will help please do click the accept button for my efforts.
Posted on Jun 05, 2010
  • maclas Jun 05, 2010
    Thanks for the "not so good news" My long range plan is to update other laptops on network to Win 7 64 bit but not until I feel comfortable with the new system. I may be cynical, but once bitten twice shy with new O/S. I will look at the print server suggestion but I do not wish to load up my small network with hardware.if there is another way.
    Regards
    Maclas
  • Grand Canyon Tech
    Grand Canyon Tech Jun 06, 2010
    Other ways is print servers there only what $35-60 bucks, because you just cannot share a printer one one computer and expect it to print with a 64 bit os.
    Now there is a router from apple called the express where you can hook up the printer to it but that even is $99 alone. So I wish there was another way,
Problems 64 bit win7 to shared 32 bit xp
insatall the 64 bit driver on the 64 bit pc then when asked if its local or networke choose Local set the bottom most drop down menu to standard tcp connection click next then in the address/location box type the IP address in manually
click next and finish installation job done
( your not sharing the printer to the 64 bit system - your installing the driver and allowing the Pc to share its connection with 32 bit systems)
Jan 18, 2014 | HP LaserJet P2015n Printer
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
Is there a way I can print wireless from my laptop through the desktop attached to the Canon Pixma MX310 printer?
Yes.
The desktop and laptop both need to be attached to the same network.
On your desktop:
Go to Control Panel, Printers and Faxes
Right click on your printer, and click on "Sharing"
Share the printer on your network
On your laptop:
"Add Printer"
Choose a "Network attached Printer"
Browse for the printer, and add in.
Microsoft page:
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Picture guide:
http://hubpages.com/hub/Share-Your-Printer-over-a-Home-Network-LAN-with-Windows-XP
Jan 12, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma iP3500 connected to Windows Server 2003 x86 Standard. Client - Windows 7 x64. When adding it, finds it through AD but it tries to find the drivers, checks Windows Update and it can't find...
have you installed the printer as a shared network device with its own network path then you can install on other printers as network printer using that network path assigned to the printer
Oct 18, 2010 | Canon PIXMA iP3500 Printer
How do i share this printer from win xp to win vista? i have 2 computers side by side and want the printer to serve both computers?
Easiest way is to install it on one computer, then make sure it is shared with all.
On the other computer, do a search for printers on the first computer, and install it on the second one.
It should be literally that simple, so long as there is at least a peer network, at the least, as a common link between both computers.
-a.
May 13, 2010 | Canon PIXMA MX310 All-In-One Printer
I need a 64 bit Canon D780 printer driver...where can I download? I went to canon, but their drive is only a 32 bit
Okay so this may not help you now, but I just got a hand me down D780. After much frustration and research here's the solution that I was able to work with. It isn't perfect; but it's something....
So here are the steps for network shared installation; assuming your D780 is installed on an old xp desktop and you're using a Win-7 laptop. If you're using the printer directly on your Win-7 machine, just use the local printer installation after the XP mode has been installed.
1) You'll have to install WinXP mode on Win-7 using the steps listed on this link. If you have a genuine Win-7 copy installed, this download and installation is free, courtesy Microsoft.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
2) After installation, you'll have to change network settings for your virtual pc. This step is necessary if you want to be on the same home network and want to see the printer! Never mind if you don't understand this logic. Just follow the steps and you'll do just fine. To change the network settings in vPC: click Tools; click Settings; select Network from left; then for Adapter 1 choose the actual network adapter connected to your router (simply put: select the wireless adapter or wired adapter you're using to connect to your actual router or home network. You can find that from Change Adapter Settings in Network and Sharing.) Click Ok.
3) Now add the printer as local or networked following your usual XP steps. You should be able to see the printer. If not, open a command prompt window, check your ip to make sure you're on same network. If not, or if you don't know how to do that, just type in ipconfig /release enter and then ipconfig /renew enter. Try to connect to the shared printer by pinging the ip of the host computer. If the ping works, you should be able to see the printer then.
Connect printer and use in XP mode. Not the best solution, I know. But it's free and at least lets you print from your laptop, given the circumstances.
Feb 21, 2010 | Canon imageCLASS D780 All-In-One Laser...
Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Feb 10, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Canon ip4500 printer driver won't install
check the canon website to see if they vista drivers for this printer. It might not be compatible with vista.
Jul 31, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Wireless printing
The MP830 does not include the ability to do Wireless Network printing. You can however, connect this printer to one of your Windows or Mac PCs and share it on the network, which is wireless, therefore accomplishing the same thing.
1) Install the Drivers and Software that came with your Printer.
2) Go to the Control Panel > Printers & Faxes
3) Right-click your printer and click "Sharing"
4) Choose Share this Printer, and give it a name.
5) You can then on, use the Add Printer Wizard on any other Windows PC and install it by searching for network printers.
Step 1 is the same for Mac
2) Go to System Preferences > Sharing
3) Check the box for Printer Sharing
4) Any Mac on the network can see it!!
5) Added treat: go to http://apple.com/bonjour to install bonjour for Windows, using this software you can print using any Mac printer on any PC
Jan 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
32 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
