Question about Danby DPAC8020 Air Conditioner
Motor or capacitor problem
I have to spin the motor by hand to start,it has high speed and med. speed now speed,is this a motor issue or is it the capacitor that is gone.Thanks:Mark
  • 146 Answers
I would test the cap it needs to be tested in uF or just replace the cap it is the cheapest option for you if you cant test it. over time the motors bearings wear out and the stater gets to close to the magnets also causing the same issue hope this helps. and by the way a 5uf 440 vac cap is like 12 dollars
Posted on Jun 05, 2010
Testimonial: "Thanks alot mopar440man,very helpful i will get a new one.Thanks:Mark"
Runs fine on low speed hums on high speed (turns slowly) is it a capacitor problem, internal windings or controller?
Motor itself is the culprit.
Capacitor helps the motor to start spinning from a dead stop, so NO, it is not a capacitor problem.
Probably high speed windings. Means - New Motor needed.
Another possibility, is the controller could be sending power to "Both" sides of the windings: High speed & Low speed at the same time. But normally when this happens, you hear a loud buzz type of sound, motor will spin slowly - if at all.
Good Luck
Mar 11, 2015 | Pool & Spa
Why is it that i only have a low and med final spin and not a high speed final spin after replacing the motor and thr shift clutch?
somthing to do with motor pick up coil allignment
the coil on the back needs it position set as per the service manual allignment check the clutch is fully engaged
also check brake isnt on a bit
etc
orrrr a contact on the motor connection plug is a bit burned...
Dec 08, 2014 | Speed Washing Machines
Fan will not run without starting it yourself and will not run high speed at all
Sounds like an old unit with a bad run capacitor or
check the components on the board for burnt wiring.
Fans on window units are controlled by a 3way switch. High, Med., and low. Your power and in most cases a capacitor which doubles for the compressor and fan.
So it can only be 1 of the 3
Burnt out windings on the motor
Bad switch
Bad capacitor
May 01, 2014 | Haier HWR06XC7 Air Conditioner
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
I have a magnatek, 115v. 60hz. 8.0a. 1/2 hp. 1050rpm. a.o.elect. motor. It has a 7.5 mfd. 370 vac capacitor. It has 2 brown wires wired to the capacitor and a white wire labeled com. It also has 4...
Just wire up the black wire and cap the others. This will allow the motor to run on high at all times. You have a variable speed motot. Tie the white wire to your commom and the black wire to your source.
Jul 01, 2011 | Dryers
WILL NOT AGITATE
Will it spin? Have you tried the Delicate cycle?
If it is like my washer, it appears that the high speed part of the motor is the issue. If when it comes to the point where it is supposed to start agitating, but all you hear is a buzzing, grab the tub, the outside edges, not the agitator (you're going to have to use a magnet to override the safety) and turn it clock-wise, and it should start to agitate (you might have to do it a couple times if you don't get it fast enough). Close the lid, but make sure it doesn't stop or you'll have to do it again. When it goes to the low speed agitation, open the lid and make it stop. Close the lid and it should start right back up. When the washer spins, listen for when it goes to the high speed spin, you probably won't hear it gain much speed (it should sound much faster if working correctly).
The motor (which in mine has already been replaced once) kit that is available (~$200-$250) will require some minor re-wiring, as they added a capacitor to the electrical system due to a problem with the previous design (yes, I've had that problem, which was a low speed motor issue, where the washer wouldn't spin on low speed and now it appears to be screwed up on high speed motor.) I'm weighing the options of just waiting for black friday and buying a new washer since ~$500 on motors for this washer is just unjustifiable and I won't be buying another GE, that's for damn sure.
Sep 28, 2010 | GE WBSE2090A Top Load Washer
I have an intertherm central air unit in my mobile home that does not change fan speed when I click the fan speed switch. I've checked the fan relay which is good and energized in the ac mode which should...
You may ahve a bad switch but sometimes when they are worked on the servicrman bypasses the switch. Fan speeds are color coded black high blue med yellow med high and red low. Just for your info. Russ
Aug 16, 2009 | Heating & Cooling
Have weatherking furnace, Pilot lites but no blower
I am thinking the fan is bad if you can disconnect the fan motor leads and ohm them out. White is common Red is low speed Black is high speed. You might have other colors like blue which would be med speed and maybe orange witch would be med low. There is a small run capacitor on the fan so replace both fan and capacitor at same time. After you ohm out the motor of course. You should have resistance on all leads. Use white as the main one and check each speed. Replacing the motor isn't too tuff little hard getting it out of squirrel cage
Dec 20, 2008 | Heating & Cooling
Fan on furnace not spinning
check the fan capacitor first. its a little silver flat battery looking thing near the motor. be sure to kill power. test mf value stamped on the side with a meter, or take to a motor shop and test. if its good the motor is bad. . pull whole blower assembly and change the motor or take to motor shop and let them change. label all wires and where they go and the color. it will be tough if you don't know motors and all but generally white is to white and is common or neutral. black is high speed for ac . red is low speed for heat. brown and brown with stripe go to capacitor. blue and yellow are med and med hi speeds and taped off or put on vacant terminals. be sure to clean wheel when you have it out. good luck. you can't make to many notes , mark stuff with a sharpie pen as you dissassemble. note rotation of wheel, location of screws, clearances of wheel on each side check rotation of wheel on completion, cups into the wind. <------ )
Nov 21, 2008 | Heating & Cooling
Danby DPAC8020 Air Conditioner Logo
138 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
