Question about GE Microwave Ovens
My microwave Model JVM1190BY with WB6X63 rubber belt is sqeaking
My microwave WB6X63 rubber belt began sqeaking. I found bottom edge of the belt was riding against the bottom edge of the motor pulley. I replaced it and now the new belt turns down flat against the bottom edge of the motor pulley. What is causing this? Is this normal If not what the fix? The Model Number is JVM1190BY 001, Serial Number is: RS 952637S This Model does not have a turn table. It has a paddle like fan in the top turned by a motor with a rubber belt.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Turn Table
This could be a failing turntable motor, but more likely your turntable support has gotten bent. That's an easier and cheaper problem to solve. Excessive heat can sometimes make the legs of the support bend so that the center is raised up far enough that it won't always make good contact with the motor. You can test this by running the microwave empty for a few seconds. It may hesitate to turn or stutter. Next try it with a bowl with several cups of water in it. The extra weight may push it down so it makes good contact and runs without a hitch. The way I fix these is to use a stove burner or a torch to heat up the legs and bend them up a bit. Then I quickly set up or clamp the support so it's held in the proper position for a few minutes until it cools. One way to hold the heated support in position is to place an object under the end of each leg and put something slightly heavy on top of it in the middle. If you need a new motor or just want to see helpful exploded views of your model, see the GE or Sears parts Web site: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Posted on Dec 24, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
SOURCE: Microwave turntable makes noise
yes motor may be bad or something is stuck . its not difficult to change .it is located at the bottom and has a wire connector with 2 spade clips
Posted on Oct 31, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Dec 02, 2008
bestdarngood
  • 3037 Answers
SOURCE: My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
How do i fix my GE microwave jvm1630wb 006 turntable that is not rotating?
Tip it over and see if you can remove the bottom. They are driven by a small servo motor to a rubber belt. The belt may have come off or broken. There is often use of security screws on microwaves as they are so dangerous.
Jan 29, 2018 | GE Microwave Ovens
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Turntable not working
Remove the bottom cover to the oven and check to see if a rubber belt exists, if so it may have stretched and may be slipping. Replace the belt if one exists.
Dec 22, 2013 | Sharp R-1610 Microwave Oven
GE JVM1190BY died
The keypad control board may be the problem, or the inverter board if 7 years old or less, cost should be considered.
Apr 29, 2012 | Whirlpool Microwave Ovens
G E microwave model # JVM1190BY has reading sensor error or error 3 or at times just starts up when we are not even using. tried shutting circut breaker....whats going on
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
My gold star microwave worked lastnight. Went to
The outside bottom of your microwave usually has a belt hidden underneath a small cover directly under the turntable. This belt sometimes falls off or breaks, and sometimes the motor that turns the belt fails. Most time the motor can be found if you remove the main top cover of the microwave, about 10 screws.
Parts can be easily found at your local appliance parts store.
Best of luck.
Jan 20, 2010 | Goldstar Microwave Ovens
Our handle broke on our GE Microwave convection ove need a new handle or door Model no JVM1190BY 002
Here is a link to PartSelect.com, I have used them for my microwave repairs in the past and they usually ship the items fast.
I have put in your Model number, but the closest that I could find was JVM1190BY003. You can look at the picture and determine if the parts look the same and the picture will show you that you will have to take the entire door apart, (You may already know that).
http://www.partselect.com/ModelFrames.aspx?ModelID=386757&ModelNum=JVM1190BY003&mfgModelNum=&ManufactureID=2&Selected=00110600i01&Position=1&mfg=GE&Type=&Mark=1
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Oct 26, 2009 | GE JVM1190 Microwave Oven
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Above range microwave
According to the installation instructions for this model, the distance from the cooktop surface to the bottom edge of the cabinet (and thus the top of the microwave) must be 30" or more.
Owner's manuals and installation instructions can be downloaded here: http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 26, 2007 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
