I REPLACED ST9120C 2002 WHITH A ST9120U 1011. I GET NO CONTROL VOLTAGE OUT TO THERMOSTAT ON A RESEDENTIAL YORK DUAL PAK A/C. THE WIRING DIAGRAHM DOES NOT ACCOUNT FOR ALL OF THE WIRES.
  • steve thomas Jun 06, 2010
    I DID NOT CHANGE THE T-STAT, AND I DEFINITELY TURNED POWER OFF TO THE UNIT BEFORE SERVICING.I DO HAVE 24V. TO THE UNIVERSAL ELECTRONIC FAN TIMER BOARD BUT I DON'T HAVE 24V. COMING FROM THE R TERMINAL ON THE BOARD WHERE T-STAT WIRES CONNECT.THE DIAGNOSTIC LIHGT ON THE BOARD FLASHES A NORMAL OPERATION SIGNAL.THE DIAGRAHM BOOKLET THAT CAME WITH THE BOARD IS NOT VERY CLEAR. NEED TO POSSIBLY LOCATE A DIFFERENT CROSS OVER WIRING DIAGRAHM? NEED A LTTLE HELP. THANKS.
  • 909 Answers
Evaporator models are normally exact.and matched to their correct condensers. They can be adapted sometimes but always small issues arise. Possibly get the correct original part to match what you have just bought.Check the gas content as well because the system also has its own protection to low gas and also wont start up.
Posted on Jun 06, 2010
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. First if you didin't turn the power off to the unit your thermostat controls before switching the thermostats then you probably blew the car like fuse in the unit. You will have to go to the unit and find the fuse and see if it blew which it probably did. This is what the fuse should look like:I REPLACED ST9120C 2002 WHITH A ST9120U 1011. I - 4a50998.jpg
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
St9120u
The X and C are the incoming low voltage from the transformer. They go to the X AND C with the xtrfm in the middle. Hopefully you marked all your motor leads!?!
Nov 28, 2017 | Heating & Cooling
Blower runs without call for heat after replacing the board wiht the st9120u 1011 honeywell
sounds like it may be wired in wrong only guessing but its either that or the control board in heater may be faulty
Nov 17, 2010 | Heating & Cooling
CT3200A101 FURNANCE WONT COME ON WITHOUT ME TURNING FUSE BOX ON-OFF-ON NEED TO SEE DIAGRAHM OF THERMOSTAT WIRING HOOKUP
THE VOLTAGE ON TRANSFORMER IS NOT ENOGH ,SOME TIMES THERMOSTATS HAS A RESISTENS THA IT BURNS,2 UNPLUG FURNES 10 SECONDS PLUG BACK ,3 HEATIG MODE VALVE OR ELECTRONIC PILOT FAIL
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
2004 Dodge Dakota
Replace your resistor if you haven't already. I had the same issue with mine, it only worked on high.
Nov 24, 2008 | 2004 Dodge Dakota
Will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Jun 03, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
585 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
