Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mitsubishi MUH09TW Wire Diagram - Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I need a diagram for a 2004 Mitsubishi Endeavor that shows what pin number on the wire harness from camshaft position sensor to the computer.
To get the diagram you are looking for:
  1. Google 2004 Mitsubishi endeavor wiring diagram
  2. go across the top and click on images
  3. click on the photo
  4. when it opens, click on visit page
  5. then you will be able to view or maybe download diagrams.
Hope this helps Mike
Mar 18, 2016 | Mitsubishi Cars & Trucks
1989 mitsubishi mirage speaker wiring diagram
Mitsubishi Mirage Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Nov 08, 2012 | Cars & Trucks
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Mar 20, 2011 | Mitsubishi Raider 2006-2007 Car Radio...
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
I cant find a 2001 mitsubishi mirage stereo wiring diagram
Please forgive me, as we are not allowed to copy and paste items, but this is the only details i could find, hoping this helps you.
2001 Mitsubishi Mirage Car Radio Wiring
Diagram
Car Stereo Antenna Trigger Wire: N/A
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Yellow/Brown
Jan 19, 2010 | Car Audio & Video
Wiring diagram 4 radio on 97 mitsubishi mirage
1997 Mitsubishi Mirage Car Audio Wire Diagram
Jul 21, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Wiring diagram for audio system replacement? First time replacing a car audio system. I'm OK with wires connections but color codes does'nt match at all.... No diagram found in manual nether on actual...
2003 Mitsubishi Galant Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Black
Car Radio Switched 12v+ Wire: Blue
Car Stereo Antenna Trigger: N/A
pls rate
Mar 15, 2009 | 2003 Mitsubishi Galant
Mitsubishi magna sterio wires
first of all you should always use a wire harness when installing a unit into a vehicle you should never cut the factory harness but guess you already did so here is the wire diagram for your car hope this helps http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Sep 24, 2008 | 2002 Mitsubishi Lancer
Radio wiring
1996 Mitsubishi Montero Car Audio Wiring Diagram
Car Stereo Antenna Trigger Wire: White/Black
Aug 29, 2008 | 1996 Mitsubishi Montero
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
177 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
