Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Has been on start up mode for 4 hours what is wrong?
Turned it on and the filter is working,I can hear it but no readings.
  • 297 Answers
Is the green 88 nuber on?
Posted on Jun 15, 2010
Ice maker quit working
Brenda, try the following.
1. disconnect power from the wall.
2. open fridge and freezer doors and leave them open for at least 5-6 hours. salvage foods you can.
3. after a few hours you will see a puddle of water under the fridge.
4. clean the floor and the fridge and freezer of any collected water.
5. power up the fridge and set at recommended level say 4.
6. you will hear humming noise. Let the fridge and freezer cool.
7. dont overload food.
good luck
Apr 08, 2014 | Whirlpool : GX2FHDXVY 22 cu. ft. Bottom...
The ice machine stopped working. You can't hear the water run in the ice machine. I replaced the water filter.
fill the Ice Maker with a 1/4 cup of water using a turkey baister. wait 2 hours and see what happens.
Sep 03, 2012 | Kenmore Side by Side Refrigerator
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
I got a diesel DZ7149 digital watch with the wrong instruction booklet, the date shown is correct but the time is wrong. the instuctions I have found on line for this model aren't working for me! I can...
1. Press and hold the "SET/EL" button until the display changes to "LIGHT OFF" 2. Press "MODE" until the date section of the display reads "HOUR". Use the "LAP/RESET" button to decrease the value and "ST/STR" to increment the value 3. Press "MODE" to adjust the minute value and then the second value 4. When finished, press "SET/EL" to return to the normal mode
Dec 29, 2010 | Watches
I need to reset the clock on a sony rds car radio i changed the car battery & the clock reads the wrong time & hasn't reset itself, how do i do it manually?
I Realised that I needed to press the shift button to go into set-up mode then press 2 repeatedly till clock appears, press 4 hours flash, set hour by turning volume knob, press 4 again mins flash, change via volume knob, then press shift twice to return to normal setting, the same applies to setting colour, & display (scrolling mode).
Nov 08, 2009 | Sony Car Audio & Video
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 17, 2008 | Toshiba 46H84 46" Rear Projection...
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Aug 12, 2008 | Timex 27191 Wristwatch
I have a Panasonic EH100 HDD/DVD recorder. Yesterday I left it on for several hours playing a DVD when I realised I switched it off. Shortly afterwards I turned it on to watch a program and it went into a...
Holding certain buttons down at power up can activate unintended test modes. Wrong sequence can lock up processor! Unplug and let sit for 24 hours to re-set processor. Turn set on as normal. If you can, remove DVD before this procedure to avoid reading at start up
Apr 21, 2008 | Televison & Video
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
46 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
