Question about Audiovox SP6CDP 6-Disc CD Changer
I have 3 wires one direct to battery one ground what is he 3rd wire go to
  • 122 Answers
Perhaps is the ignition or a remote terminal.try to connect it to the acc+ of yur car
Posted on Jun 06, 2010
Fusible link blows when ignition is turned off
According to Dan B. on answers yahoo.com: "missing spacer. The heavy wire from your alternator goes directly to the battery. If that wire is grounded, you are sending battery power directly to ground - blowing that link. That wire is not a ground wire - I don't care what the color of the insulation is - black or red. "
Apr 20, 2015 | 1989 Chevrolet C1500
3 lights to a 3-gang (3 swi tches). Replacing switches. Current switches>2 have 2 blk wires & no ground wire. 3rd switch has a ground wire. New switches all have a ground wire. Should I wire all 3...
All 3 switches should be grounded, plus one box should have a ground wire to the box ground screw, all ground wires into the 3 gang should be connected together, run a 4th to the metal box and one to each switch ground.
May 22, 2014 | Home
I have a 2007 Infiniti G35s sedan. I installed an OEM spoiler & spliced the spoiler wires to the 3rd brake light wires. Non of the brake lights work now including the 3rd & spoiler. What did I do?!...
Sounds like you have lost ground somewhere along the way. might try running a ground from spoiler to frame or simply replacing wires back to original and trying again. Would put my money on a ground wire. good luck
Aug 12, 2012 | Cars & Trucks
3rd brake light not working
If the 3rd light is good when connected directly to the battery or a 12 volt power source, you may want to check the wiring. There may be loose wires or loose ground connecting that light. Check also for bad wiring which may need replacing.
Jan 28, 2012 | 1995 Subaru Impreza
How to add amp
If you have all wires to connect your amp.
1st dissconnect your ground on your battery.
2nd connect live to your battery and poke it through the firewall into your car and run it down the door sill of your car to the boot.
3rd. reconnect your ground to your battery.
4th. Connect RCA Cables to back of your head unit inc the remote (thin wire with RCA) The remote needs connecting to a blue and white wire in the connector blocks for your stereo.
5th. Run RCA cables down the opposite side to where the live is running (live on left RCA on right)
6th. You need to sand down spot in your boot of your car, paint and rust free for your ground wire for your amp.
7th Connect ground to a metal screw or bolt nd tighen it to your spot you have sanded. (may need to drill hole)
8th. 1st connect ground to your amp. then live, then remote, then speaker wires.
If you need any further info or have any problems let me know and I'll troubleshoot for you.
Hope this helps you to fit your amp..
Mar 05, 2011 | Sony Car Audio & Video
Don't know if my amps wired right it has 2 power inputs and 2 ground inputs do I bridge them or run seperate wires?
If I am not mistaken one power input goes directly to the pos + side of your battery (Use minimum 10 gauge stranded copper wire for this) and the other goes to the stereos (usually blue wire and can be regular 16/18 gauge wire) that is either used for (an amp or power antenna) In your case, an amp. So when you turn on/off your stereo your amp will also turn on/off . For the 2 ground wires just make sure you run at least one of them (preferebly with 10 gauge stranded copper wire directly to the neg - side of the battery and the other one can be ran to chassis ground and may be 16/18 gauge wire. Good Luck.
Jun 27, 2010 | Car Audio & Video
It takes three plus times turning the key to start before the starter turns the engine over. The engine starter clicks each time the key is turned to start but does not turn the engine over until the 3rd...
You Probably have a Bad starter motor, or Starter solenoid, Take the starter, and get it checked, most autopart dealers will test it for free.
Feb 14, 2010 | 1999 Subaru Legacy
1997 3rd brake cargo light
white wire makes the light come on with dome lights, orange wire should be constant power, black is ground and blue w/white should go directly to the brake light switch, both white should be the same connection if problems let me know
Feb 16, 2009 | 1997 Chevrolet C1500
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Audiovox SP6CDP 6-Disc CD Changer Logo
69 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
