Question about LG LB8000ER Air Conditioner
My A.C doesn't turn on
It overheated the extensionn cord and the plug reset button doesn't work.
  • warlock_ange Jun 05, 2010
    how can i fix that?
    should i open up the capacitor to solve that problem
    Gonna try it out...thank you :)
  • 146 Answers
Cause don't use an extension cord. probably fried the gfi or burnt other wires if you have a meter just test it
Posted on Jun 05, 2010
  • mopar440man Jun 05, 2010
    i would open up the gfi/reset and jump the power wire if this works i would buy a new cord or cut out the reset cause you have a breaker
My black ink doesn't work
did you try changing the ink cartridge??? if yes then remove the black ink cartridge and then clean the copper contacts with a lint free cloth and then put it back in. if it helps well and good however if it doesnt follow the steps below.
1. Without turning off the product, disconnect the power cable from the rear of the product.
2. Press and hold down the power button for 30 sec.
3. Release the button.
4. Check if black works or not.
5. do a reset if it does not work:
Unplug the power cord from the product, and wait 20 seconds.
Press and hold # and 3 while plugging in the power cord to the product
Release the buttons after the product starts up. The product will now be reset to factory defaults.
Check if it works or not. If it does not then service the product.
Jan 11, 2013 | HP Photosmart C7180 All-In-One InkJet...
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
NewAir AC 1400E. No green light on plug. Pushing reset button does nothing. Has been running OK. Outlet is live. Does not need draining. Any ideas?
If the reset button is not doing what it should. Try these solutions listed below::
Remove and replace the water collection bucket. Making sure the float valve (if your has one) inside the top of bucket is not stuck in the UP position. Also, be sure that the bucket fits squarely into the holder from top to bottom. If it doesn't, it won't trigger the buck removal safety switch.
If that didn't work do the following:
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
Wait 15 minutes, plug the unit in and turn the Master ON/OFF Switch to ON.
Generally, doing the above, allows the unit to reset and revert back to the original factory settings and you can proceed from there. If it still does not work, there may be a problem with the cord & reset switch. The best way to find out is test the continuity of the cord, with a multimeter.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 15, 2011 | NewAir AC-1400E Portable Air Conditioner
The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
Feb 04, 2011 | Heating & Cooling
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
LG LB8000ER Air Conditioner Logo
166 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
