Question about Sony VAIO VGN-FS742/W Notebook
Screen is flickering
I've had a problem with the screen on this laptop flickering and going out from time to time. It's been an issue on and off since about the first year into owning it.
When it was under warranty the repair support had me run a series of tests and then told me it could NOT be a hardware problem.
We replaced the inverter recently and restored the computer hoping it would solve the issue but the flickering continues. Sometimes it is not bad but at other times it is like fireworks going off inside the screen.
It seems worse since I restored the computer than it was before. Just wondering what else it could be. There is also horrible noise (like conflicting programs) when it is starting up and the Windows sound plays. Has been a problem since day one. Have tried everything we can.
    Master:
  • 404 Answers
Flickers dont occur because of invereter, inverter controls the light and the light only meaning the contrast of it so who ever told you to change inverter is stupid.
the problem is eiterh the cable connector "70%"
or the screen itself "20%" or the graphic chip "10%"
the percentage is the chances of what it is. what I bet on
Posted on Jun 05, 2010
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
Screen flickering
I've had a couple of problems with mine, what it usually is is the wires coming loose, I've also had to replace the screen.
May 20, 2012 | Toshiba Satellite L505-S5966 Notebook
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
The screen flashes whenever I move it around it looks like the scrren is off when it turns black.
As you say the the screen flashes whenever you move the laptop the issue might be with the internal connections. However, to isolate the issue with the software or hardware.
Restart the laptop, press F10 to enter into the BIOS screen. Then move the laptop and check if the BIOS screen flickers or not.
If the BIOS screen flickers then we can confirm that it is a hardware issue and your laptop needs to be serviced to fix this issue
Jun 15, 2010 | Computers & Internet
The laptop screen flickers all the time and it distorts the screen. If i plug into a desktop monitor that works fine. What is the problem? and how do i fix it?
hi chizuk, if the screen flickers all the time, pls call our support line at 1-877-4-536686. This issue needs to be addressed and it is possible for a depot repair due to screen problem.
Hope this helps...
May 08, 2010 | Lenovo IdeaPad Y510 Notebook
Screen flickering
That really depends on when it flickers, does it flicker when you move the display open or closed or when you press some part of the laptop?
If it happens when you press a part of the laptop, the display cable could be loose, thats unlikely.
I recently had a similiar problem with a toshiba laptop, the screen would flicker when pressed on the bottom left side of the laptop.
I checked the wires and they where fine, in the end I seem to have fixed the issue by pressing on the top cover where the issue happens and at the same time from the bottom from the same spot, what I did on that laptop, there was a cover that I could remove so I could press directly on the mainboard, pressing directly on the mainboard with my fingers and at the same time pressing down from the top seem to have fixed the problem on that laptop.
Sep 11, 2009 | Acer Extensa 5420-5687 Notebook
Acer notebook aspire 5102 WLMi screen flickers
Hardware, sound like the cable that attach to LCD panel was losing...
Nov 17, 2008 | Computers & Internet
Sony VAIO VGN-FS742/W Notebook Logo
202 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
