Question about Microsoft Zune JS8-00001 Digital Media Player
I have a 30 GB zune and I am trying to get the front off to replace the battery. Do I just pry it off? Seems to be stuck or something
  • 600 Answers
Try this,
this one is for taking apart for repair of the lcd, but it dismantles the unit so you can still use this as a guide,
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Posted on Jun 06, 2010
Zune 30gb wont start
Update the firmware in that zune and you should be doing great if not microsoft has recalled some of there 30 GB versions due to the latest zune error.
Apr 23, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune player hardware problem
eeh, this is a pretty bad problem. I would ask you if you had a warranty, but you took it apart... I can only suggest getting a new one, not a 30 GB because that one seems to have the most problems. Fixing it though, you could ask the Geek Squad about it. Next time it freezes, just wait for the battery to die, then charge it and restart it.
Jan 20, 2009 | Microsoft Zune JS8-00001 Digital Media...
When i plug the zune into my computer, it won't recognize it
It's a glitch with Microsoft. All 30 gig units are affected. It's a leap year and the extra day threw the software. Let it discharge overnight and plug into your computer in the morning to load. Microsoft is supposed to have a fix. Thousands are affected.
Jan 01, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Zune 30 Gig stuck in partial boot up.
mine shows the same thing. i've tried evrything. im thinking i might take it apart. at first i thought it was the battery. but now i think its the hdd.
Zune brown 30 gb
I'll post an solution, IF I HAD ONE! (ill get one soon)
Feb 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
235 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
