Question about Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer
Hotpoint wd645 not heating up on the drying cycle evrything else seems to be working the dispay doesnt show any fault codes
5 Suggested Answers
COXY
  • 76 Answers
SOURCE: Hotpoint Aquarius+ WD645
Yes, you will need a test meter. unplug machine, remove to, in the middle on top you will see a heater, you will need to test this. there is also a fusable link, that is incorprated in one of the wires that go to the heater. you will also find to thermostats linked through the wiring, one of these may have a reset button on it.
Posted on Dec 07, 2007
SOURCE: Hotpoint WD860
my washing machine WD 860 has 'stuck' with the error code F12.
IT STILL HAS SOME WATER IN IT BUT EVEN AFTER POWERING DOWNE ALL NIGHT I CAN'T OPEN THE DOOR TO REMOVE MY CLOTHES.
what does error code F12 mean? any idea how to by pass it open the door?
Posted on Oct 31, 2008
SOURCE: hotpoint wd645 flashing f-08
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Posted on Jan 10, 2009
barkencoa
  • 3463 Answers
SOURCE: my Hotpoint Ultima keeps displaying an F10 fault
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Posted on Jan 17, 2010
My aquarius washer/dryer wd645 is flashing f-07
dont warry it will be for few time then it will be ok
Mar 30, 2015 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hi,my hotpoint df 41 trips the mains every time it starts the heat water cycle.I assume the element is faulty.I have looked underneath and all seems dry and clean.Can i buy and fit a new element myself?
Yes, you need to remove the element taking note of the connections and wire colors. Also note the seals used on the element. Remember that sometimes a "cold" element does not show the fault and only once heated does the "short circuit" show. Take the element with you to the dealer as many different elements (shapes and sizes as well as electrical connections on elements are available).
Jun 01, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I have a hotpoint dryer ctd40, it seems to eb
either your heating element,hi-limit switch,cycling switch, thermal fuse, or missing one leg of input power i.e.120volts instead of 240 volts
Oct 29, 2009 | Dryers
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint WD72 - error message heating or Heater
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-2.jpg hotpoint-wd72-error-message-heating-or-04t3bj0jgktmuqmnt3s3ejb0-2-7.jpg
Nov 01, 2008 | Hotpoint Ultima WD72 Front Load...
Dec 07, 2007 | Washing Machines
Hotpoint -Ariston Aquarius WD645 Front Load All-in-One Washer / Dryer Logo
97 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
