Question about Water Tech Pool Buster Max Cg
The pool buster won't run at all.
My husband was cleaning the deep end of the pool with our pool buster and lifted it out of the water long enough to extend the handle. It quit and wouldn't start up again. It won"t take a charge. In other words it completely died. Can we do anything to fix it?
I had the same problem when I started to use mine at the beginning of the pool season here. If yours is anything like mine when I opened it up I found the motor was completely rusted and the drive gears would not turn. I'm not sure if the batteries are dead as there was a lot of corrosion on the charging terminal. It is simple to open the case and then open up the motor/battery housing - just a LOT of screws!
The options seem to be buying a replacement battery and motor pack from Aquatech the makers and replacing the defective unit. I think the cost is around $130 but for that sort of money you can buy a new one on Ebay - depends if you have the Commercial Grade unit but I've seen that new on Ebay for $185ish too
If it is just the battery you might be able to buy a replacement battery alone from Aquatech but I haven't checked it yet - on thier site it shows only the whole motor and battery unit as a replacement. In theory it should be possible to get a set of batteries made up for a lot less than Aquatech probably charges - I saw one web posting where a guy had Interstate make him up the batteries for $28.
Frankly, the pool buster seems to have a lot if issues once it gets old (past the 1 year warranty) and the battery charger had a lot to do with the issues as it would overcharge. From my research it seems a common problem that water can enter the unit if the seals on the screw in starter fail. BTW the unit is now called the Pool Blaster but to all intents and purposes seems like the same model but with a different catch on the front holding the plastic cup to the body
Hope this helps
Posted on Jun 06, 2010
Poolboy10 is correct, this is a poorly manufactured product. You won't have any luck getting help from Watertech the manufacturer. Buyer beware! I plan on getting parts from Ebay and fixing it myself, then sealing the motorbox with silicone. Good luck.
Posted on Jul 12, 2010
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
My kreepy keeps coiling at the deep end of pool and stays there what do i need to do so that it cleans the whole pool?
There are a couple of things that you can try to get your pool cleaner to cover both ends of the pool. First, use an eyeball diverter to make sure that your water flow is correct to make the pool cleaner function in the proper pattern. Your return lines could be pushing the cleaner only toward your deep end. Secondly, if your hose is connected to your filter at the deep end of the pool, it could be that your hose is not long enough to cover the entire pool. You might need to add hose lengths. You will also want to adjust your hose weights.
Jul 16, 2011 | Universal Kreepy Krauly In-Ground Pool...
Baracuda X7 stays at the deep end of the pool
With these pool cleaners, there are several things that you can try to get your cleaner to move around your pool. Check to make sure the hose is long enough to reach all ends of the pool and that it has proper hose balance. Check the return line water flow and redirect as necessary with an eyeball diverter.
Jul 23, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Ray Vac cleans only in deep end
Make sure that your automatic pool cleaner doesn't have an obstruction in the hose that might not immediately be visible. This could cause it to circulate in one end of the pool. Also, check the water pressure to ensure that it has enough force to travel the entire pool.
Jun 27, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Kreepy cleans the deep end great. It cleans the walls and bottom but will not venture up the slant to the shallow end
There are several things that could cause these automatic pool cleaners to have this problem. First, check the return line water flor and redirect it if necessary. Also, make sure that the hose is long enough to cover the entire pool without difficulty. Also, check the hose balance to make sure that it is correct.
Jun 22, 2010 | Universal Kreepy Krauly In-Ground Pool...
New baracuda automatic pool cleaner.
If these pool cleaners are staying on one side of the pool, there are several things that you will want to check. First, check the return line water flow and redirect it if necessary with an eyeball diverter. Make sure that your new hose has proper balance. You might have to apply hose weights to achieve balance. Also, make sure that the new hose is long enough to reach all corners of the pool.
Apr 16, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Dirt comes back thriugh the return when I vacuum
if your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
Jul 16, 2009 | Hayward SAND FILTER, PRO SERIES
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Does not clean the whole pool
may need to re-weight it or add helpers.
I had to add a rope system to my pool to get the creepy crawly to all the spots.
Not the best fix - but keeps the pool clean.
Apr 10, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Water Tech Pool Buster Max Cg Logo
486 people viewed this question
Top Water Tech Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Water Tech Garden Expert? Answer questions, earn points and help others
