Question about Water Pik Flow Valve Assy. Series II Bronze 325
Hi my filter has 0 pressure and there is no water coming from the pool. I think there may be a blockage. what do I do? I have tried to backwash but there is no water coming from the pool to the drain.
    Scholar:
  • 78 Answers
First, if you haven't done so already, is check all valving to make sure they are open. Next check the pump basket strainer. If clean, you may have to check the pump impellar for blockage.
Posted on Jun 06, 2010
I,ve just opened my pool and when I backwash the filter the water comes out at very high pressure. This is not normally the case certainly not for the last 10 year. Is there a problem with the filter,
No.
Nothing in filter will increase water pressure. Whatever water the pump sucks in will flow out of whatever port is open, in the case of backwash, a Waste port open. So... What the pumps takes in, you will see flow out when you backwash.
No problems that I can think of to look for.
May 13, 2015 | Pool & Spa
How do I get into the filter to check backwash valve?
you shouldnt have to go inside the filter that is done in the multiport
turn system off turn multiport to backwash till water comes out clean shut off then turn lever to rinse for about 30 seconds turn off pump again turn lever to filter you should see more water pressure coming out of pool return
Sep 10, 2013 | Hayward Pro Series 18" Above Ground Pool...
Chlorinator esr 160 pool pump
possible bad multiport not in filter mode
Aug 08, 2017 | Pool & Spa
I have a hayward s166t filter, guage reads 0 and sight glass water does not swirl when backwashed
Does it show pressure when in "Filter" mode?
If not, then your pump is either not primed, Impeller is plugged, or there is not enough water in the pool, you are sucking air.
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
No pressure in the filter
Pull the pump apart, maybe the impeller is broken, put a hose up the suction line to check for blockage, is there a non return valve in the suction line? Maybe just an air leak, only takes a pin hole !
Jul 15, 2013 | Pool & Spa
I have a Hayward S310T filter. It's been running 24/7 for over a month. The water does not appear to be clear, even after floccing. How do I tell if the water is being filtered or if the filter is...
Backwash the filter. If the water coming out of the backwash line is not dirty you need a sand change. If the water is dirty you need to continue let the water filter and back washing once a week. Also make sure the six way is on filter and not recirculate
Www.theswimtimeonline.com
May 26, 2011 | Hayward SAND FILTER, PRO SERIES
De filter pressure too high water is cloudy
backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Jul 28, 2009 | Pentair 3/4HP Pinnacle High Performance...
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Water Pik Flow Valve Assy. Series II Bronze 325 Logo
175 people viewed this question
Top Water Pik Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Water Pik Pool and Spa Expert? Answer questions, earn points and help others
