Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Coil freeze up.
I have a maytag mzd2766ge frigidaire. the freezer work find. until the coil freeze up then there no cold air come in to the refrigidaire until i used the hair dryer to defrost the coil. then the freezer and refrigidaire is cold again. please help!
    Problem Solver:
  • 14 Answers
Sounds like you have a problem with the defrost timer. usually they are at the back on the bottom of the fridge and have a little nob that is supposed to turn as a clock.
mark it and come back later to see if the timer moves, if not then there is your problem
Posted on Apr 10, 2008
The refrigerator side of my Maytag, model MZD2766GE, is warm. The freezer is working fine. I feel cold air coming out by the crispers at the bottom but no cold air coming out at the top. HELP...Single...
If sounds like the top cold air tube is frosted up. If you remove the rear shield over the evaporator coil you will see the tube opening. If you use a hair dryer (not of the hottest setting) and blow hot air down the tube you should be able to clear it.
Jan 31, 2012 | Maytag MZD2766GES Side by Side...
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Maytag MZD2766GE refrigerator side is not cooling well. Freezer side has no problem. Where are the coils for cleaning? Any other ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Maytag MZD2766GES Side by Side...
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
162 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
