Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Menu screen popping up
I have a toshiba and every now and than the menu screen pops up all by its self,first i figured it was the batteries or the remote was bad, so ichecked all that and it still does it. Than i reset the tv and it went away for about an hour and came back. Ihave checked all the web sites and it shows nothing for this. PLEASE tell me how to remove it or stop it from coming up.
    Champion:
  • 222 Answers
Remove the batteries, un-screw the back cover of your remote, you'll find a circuit board take that off, clean the other side of that board (the one painted green) with a cotton slighty wet with rubbing alcohol as well as the black carbon on your remote pad, let it dry put it back together replace with a new battery, I guess this'll work
Posted on Jun 05, 2010
How do i enable pop ups on google chrome
Turn popups on or off:
  1. On your computer, open Chrome.
  2. At the top right, click the icon you see: Menu or More .
  3. Click Settings.
  4. At the bottom, click Show advanced settings.
  5. Under "Privacy," click Content settings.
  6. Under "Pop-ups," select an option:
Aug 21, 2014 | Toshiba Satellite C655d-s5200 Laptop...
My Toshiba laptop is stuck in logging off mode. How can I fix this?
if you have a program running that is non responsive and try to shut down or restart, the computer will get stuck on the logging off screen. Often times if a computer takes a long time to do anything, it means you need to defrag your hard drive. Manually shut down the computer (you might have been pushing the Sleep button. If you can't figure it out, just unplug it and let the battery run down.) and when you restart it, go to the My Computer or Computer option, right click on your C drive, click on properties and a window should pop up. Click on the tab that says Tools and click on the Defragmentation option. The rest should be pretty self-explanatory. If nothing works. please try logging in as administrator in safe mode and doing a system restore.... please see Using Windows Vista System Restore :: the How-To Geek
Feb 28, 2011 | Toshiba Satellite Pro L300 Notebook
I turn on the phone to immediately find a pop up that says uncaught exception index 4>=4 then by its self it will go to w white screen that says app error 523 with a reset link beneath it. ive tried...
i turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
Aug 05, 2010 | RIM BlackBerry Curve 8520 Smartphone
Menu keeps popping up on screen on 52 r5wh73
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Also double check that the remote is not the problem by removing it from the room or removing the batteries
Let me know if you need more help or info.
Dec 03, 2009 | RCA R52WH73 Projection Television
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Microsoft Wireless IntelliMouse Explorer 2.0 - low battery pop up
I would disregard the pop up as in most cases the batteries are still good. I'd use the mouse till it stopped functioning. Why it does that I haven't figured out yet. I beleive a value has to be changed in the Registry. If I figure it out I will let you know.
Bud
Jan 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Asking for a password without one set
remove the bios battery and start computer. Switch off and replace battery. The password prompt should dissapear after doing the above. Hope this helps.
Dec 03, 2008 | Toshiba Satellite A135-S2246 Notebook
Menu keep popping up
the button is shorted, unsolder the button and take it out. you can use the remote to use the menu if you want, you can also buy a new switch from radio shack.
Oct 28, 2008 | Toshiba 32A32 32" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
