Question about Whirlpool LER7646E Dryer
Replacing a heating element in a whirlpool dryer LER7646EQ1
Which wires connect?
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 351 Answers
SOURCE: Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Posted on Apr 19, 2009
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
projdoc
  • 2236 Answers
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Posted on Jul 24, 2009
  • 45 Answers
SOURCE: My kenmore series 80 electric dryer does not heat.
Yes, hook it up, but before you do that Vacuumn every piece of lint out of the cabinet. Also check TCO and check the thermostats for continuity. They should all read zero ohms.If one of them is open, replace it.
Also use your ohmmeter to check the heating element, It should not show an open condition.
Posted on Jul 29, 2009
Does not heat up
what type of dryer rate these
Open The Cabinet
  • Unplug the dryer's power cord from the electrical outlet. Remove the toe panel by inserting a putty knife between the toe panel and the front panel. There are retaining clips 4 in. from each corner. Slide the putty knife blade over each retaining clip and pull the toe panel away from the dryer.
Test the Heating Element
  • If you own an electric Whirlpool dryer, locate the heating element. The heating element is the workhorse of the heating operation. The heating element is most often inside a can. The thermostat mounts to the side of the heating element can in most Whirlpool dryers. The thermostat looks like a small oval part with two wires connecting to each side.
    Pull the two wires that connect to the heating element terminals. Set a volt-ohm meter to the RX1 scale to check the continuity of the heating element. Clip each probe from the volt-ohm to each of the heating element terminals. A good element will give you a reading between 8 ohms and 12 ohms. If you get no ohm reading, the heating element is faulty and you will need to replace this part.
Jan 15, 2013 | Dryers
No heat , drum turns and wont shut off
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 05, 2010 | Whirlpool LER4634J Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
For Dryer Model LER7646EQ1, dryer runs but no heat, It could be the heating element, the thermal fuse or other. Also the dryer has been running hot.I do not know how to remove the front panel
This sounds like a faulty thermal fuse or heating element. The fact that you said the dryer has been running hot could indicate that the heating element was making contact with the heater box or the high limit thermostat is faulty. Both the thermal fuse and heating element can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a faulty component. When necessary to replace a thermal fuse it is best to change the high limit thermostat as well. They will sometimes come as a set from a parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Whirlpool LER7646E Dryer
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Whirlpool Dryer LER7646EQ1 Motor?
Could be something jamming the fan blade but if the motor shaft turns freely then your motor is bad.
May 28, 2009 | Whirlpool LER7646E Dryer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer wont start ler7646eq1
the unit ha two safety fuses they are in the back so the back has to come off
one is on the heating element housing
it has red large wires connecting to it . the fuse is on the top left of the heater housing with an ohm meter it should read a full scale reading
the other one is a white fuse on the blower housing it has blue smaller wires
it with the ohm meter should read full scale
let me know if you need more help
Jun 13, 2008 | Dryers
Dryers Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
