Question about Bosch 24 in. SHU43 Built-in Dishwasher
Like the other writer,mind to fills with water when it's off. I looked at video my model is SHU43CO2UC,I don't have that part in my tub. It could take 10-12 hours before it overflows.
  • 4,070 Answers
Your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Jun 05, 2010
I have a shu43co2uc bosch dishwasher that fails self test and displays CL on display. I believe this is a bad ntc sensor. the tub has water in it an inch or two and it does get hot but pump runs a few
If the owner's manual does not give an explanation of the error code is, in the troubleshooting guide, you'll need a service / repair manual. Perhaps calling around to a few local appliance parts and repair shops- someone can clue you in on what the problem is and how to repair it.
Nov 30, 2013 | Bosch 23 in. SHU303 Built-in Dishwasher
A Kenmore model 110 washer leaks while filling up
It is either going to be the tub gasket that is leaking, drain hose or the drain pump. Take a look at this video to show you how to get the cabinet open. Then, I would pour water into the machine by hand and find the leak. After you have done this, please post back where you found the leak and I will direct you to the parts you need and post a video to show you how to make the repair. This video is for a different model but the unit parts will be the same.
Oct 16, 2012 | Washing Machines
Whirlpool SM8281115
You probably have the end of the outlet hose too low to the ground it should be about half way up the back of the machine or fitted into a stand pipe.
http://selfix-uk.co.uk/under%20sink%20plumbing.html
or the water entering the machine will just siphon out
Mar 28, 2017 | Whirlpool Washing Machines
F 20 code and load not draining
F20 is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
* If you have no water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
* If you have water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the link for instructions: Duet_Service_F20_error
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Oct 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My frigidaire will not dispense any water, it just starts to run, we are not sure if there is any water connected but we don't see how it could have been disconnected either. How can i check and/or...
The first thing that comes to mind for me that a spoon,fork,or whatnot is stuck under the float under the lower rack in the tub preventing water from coming in,it floats up when the tub is full to tell the water to stop filling,if nothing stuck it could be gummed up and hanging up,its needs to be down to tell the dishwasher it's not filled
I hope thats it and this has helped,let me know if that isnt it and ill cover more things to check,
Gene
Aug 04, 2011 | Dishwashers
I was given a warnock hersey hot tub model 1060 aruba with no manual. im looking for info on that tub and where i can get a manual.
After i fill the hot tub it keeps drain the water from the bottom, how i can keep it filled.
Jul 02, 2011 | Pool & Spa
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Water leaking from water output at top of washer
soundsas if you have a faulty, inlet water valve. your model is notshowing up on my part look ups, but definatly replace the valve( your water hoses are connected to it. in mean time make sure to turn off water inbetween loads
Dec 11, 2008 | Whirlpool GSC9455 Top Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
103 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
