Question about Kenwood KTS-300MR CD Receiver
I wired additional speakers to my Kenwood car radio/cd player, that is in my boat. When I turned it on it played really loud and I could not turn it down. I turned it off and now it will not turn on. I have checked all the fuses and I can detect that there is power brought to the unit. Do you think that the radio some how is ruined?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
When you connect multiple speakers to one channel it drops the impedance. A radio is designed to play at 4 ohms which would generally be one speaker. When you connect two speakers to one channel it drops to a 2 ohm load which can be fatal for a radio but not always
Posted on Jun 07, 2010
My Kenwood KVT-516 has no sound, everything else works on it. Has video, plays cd's, plays radio, switches through everything all normal but doesn't have any sound coming out. Have check all speakers, amp,...
Check to see if you have a speakers A button and a speakers B button. Cycle them both on and off one at a time with something playing. This may turn the speakers back on. In addition you can check to see if you have a second room speakers feature that somehow got turned on- if so turn it off and the sound should come back. In addition you should download the manual and search for these features to show you have to deal with them.
Sep 16, 2014 | Car Audio & Video
Hello, my problem is when I insert a CD(mp3), the Subwoofer gets disabled and only the speakers works. However, when I use only radio, the woofer works fine, it's only when I play CDs. My receiver is new...
it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on) wire to turn your amplifier on.
Jan 17, 2011 | Kenwood KDC-MP335 CD Player
Kenwood KTS-300MR
you need to firstly trace the speaker wires to the unit to make sure there connected first. if they are then its a job for a car audio expert ( if there is such a thing) if the unit is connected to correctly to the speakers then there is an internal fault ..
Jul 03, 2010 | Kenwood KTS-300MR CD Receiver
New speakers are fuzzy
If it is an older vehicle you could have interference from the ignition system. You can wire the radio to be powered up from a toggle switch that get its power straight from the battery, with a fuse between the battery and switch of course. This will eliminate powering up the radio with the ignition switch and take the ignition system out of it. Also need to make sure the ground wire is grounded good and the ground wire is the same wire guage if not larger than the power wire.
Sep 28, 2009 | Kenwood KDC-MP228 CD Player
It is flashing the word protect on the screen
You have a shorted speaker wire or a blown speaker. The unit is protecting itself from damage. Did you install it? if so, pull the deck and check your connections. If they all seem fine, disconnect one speaker at a time, and turn on the radio. Make sure the radio speaker wires are taped so they don't short and cause more damage. Test each speaker wire until you find which one is causing the problem. Now re-connect all the other speakers and test. Next, disconnect the speaker wire right at the speaker that's giving you a problem, tape it off, then re connect it to the receiver. now test again. If all is ok, you have a bad speaker, if not run a test wire from the radio to the possible bad speaker and test again. If the speaker plays, you know what the problem is, replace the bad wire. Most often it's a door speaker wire or a wire got pinched during installation and took a while to short. Hope this helps
May 24, 2009 | Kenwood KDC-MP332 CD Player
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Plays radio not cds
You may have Power antenna and amp remote turn on wires switched. Your system may be looking for turn on signal from radio and only gets it when am or fm is on because power antenna wire is hooked up instead of amp turn on signal.
Jan 18, 2008 | Kenwood Sirius KDC-MP522 CD Player
My Cd and iPod doesn't have sound
Alright I fixed it. My stock Jeep stereo had a speaker amp that was wired in with the power ANT, the kenwood would turn the power ANT off when using other medias. So I had to hook up the BLUE power ANT wire up to the RED IGN wire so that when the car was on both the ANT and AMP would be on when the car was on. There are other ways of hooking this up I could have hooked the ANT wire up to the AMP wire coming out of the Kenwood so that the AMP and ANT would've only been on when the radio was on, but I'm happy with the way this turned out.
Dec 01, 2007 | Kenwood KDC-MP435U CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KTS-300MR CD Receiver Logo
66 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
