Question about Weber Q Grill
I have a problem with my q grill. There are flames only on ca 65 percent of the grill. The last long side have no flames at all. This is the first time this year we use the grill. It worked fine last year (the grill was new last year).
    President:
  • 512 Answers
Sounds like a bad regulator. Call weber they should replace it, for you.
Posted on Jun 13, 2010
How to adjust side burner on weber grills
Burner could be blocked try cleaning the burner then you should be able to adjust air mix Lpg will a bit of yellow in the flame.
Jun 14, 2013 | Grilling
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
I've had my grill for a few years and when i turned it on last night, i could barely see the flames and i had both burners on hi. I cleaned (took a wire brush) to where the flames get out and still...
You may have to recheck the tank for full. If you forgot to turn off the tank after the last time you used the grill, the tank could have leaked down. I always keep a spare full tank for just those types of problems. If the tank is full, then the regulator may have a problem. That grill should be able to get over 300 degrees.
Jul 07, 2011 | Weber Genesis Silver A Grill
HELLO. THIS IS MY FIRST TIME GRILLING ON MY OWN. MY QUESTION IS BY THIS GRILL NOT HAVING A LID WHAT IS THE BEST WAY TO COOK W/O HAVING TOO MUCH SMOKE. B/C I SATY IN AN APARTMENT COMPLEX IM CONCERNED ABOUT...
The best way to cook on a BQ and have min smoke is to put tin foil on the grill with only a couple holes punched it for fat to drain, and don't let flames flair up, use water botttle near by to squirt coals if flames appear and spray some to put out flame. What causes smoke is the fat and juices from the meats hitting flames, this method cuts 90 percent of that.
May 29, 2011 | Marsh Allan 86851 Grill
Flame can't be adjusted ,starts off mid level and gets smaller as i turn on the other burners.heat only goes to 200.this problem only happens when the temperure is 65 and lower.changed regulator and had...
Turn the tank valve off and disconnect the grill hose from the tank. Wait five minutes and reconnect the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY. Once the valve is completely open, light the burner farthest from the tank and turn the flame to high. Move to the next burner and repeat, until all the burners are lit. Are all the flame heights back to normal? If so, problem solved. If not, repeat the procedure again. If that doesn't solve the problem after the second attempt, it's time to replace the grill hose/regulator. You can purchase one at any home improvement center or hardware store that sells grills. Be sure to take your old one with you, to get the proper length and size.
Hope this helped solve your problem.
Mar 06, 2011 | Brinkmann Grilling
Low flame roadtrip grill, when both sides are on at the same time
could be blocked burners of blocked orfice , or reg on tank , which all give low pressure
May 20, 2010 | Coleman Roadtrip Grill LXE 9949-750
Can't get a decent flame after lighting the grill.
Sounds like you need a trouble shooting checklist! Click on my username, scroll down my profile and click on my tips and tricks for trouble shooting gas grill lighting issues. Hope one of then helps.
May 17, 2010 | Thermos Stainless Steel Gas Grill
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
Lack of heat
The plates protect the burners and help disperse the flame more evenly across the grill surface. Make sure the tank is completely open (knob on top of tank) and that when the burner is turned up to high, the flames out of the burners are about 1 1/2 to 2" long, mostly blue in color. If they are smaller, and the tank is open all the way, the regulator hose may be defective.
Jun 19, 2008 | Uniflame 200209 Open Flame Patio Heater
Weber Q Grill Logo
312 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
