Question about SAMTRON 55V 15" CRT Monitor
Screen too far to the left on my monitor
My screen is too far to the left. I cannot click on the Windows Title Bar and move it with my arrow. There is black screen at the top and to the right. A pc tech quickly fixed this problem for me when I used to work.
Please help as I can't see stuff that is on the left side of the screen.
Thanks!
  • stupid rabbi Apr 17, 2008
    i have a flat screen monitor, the other day my rabbit chewwed through some cables and i have had to replace them. Everything is working normal apart from the screen has all shifted to the left. I have looked at all the wires and i cant see anything thats damaged.. help!!
  • Samtron Master
  • 13,433 Answers
I think we solved this one earlyer on live chat.
Posted on Apr 15, 2008
How do I get my screen back to normal. it is too far over to the right. I cant hit the maximize box
What computer are you using?
On a Windows pc use the key combination ALT+TAB to switch between active windows
Then either:
Double click the Title bar of the window which is partly off-screen
Or - press the F11 key
Or - Click and Drag the title bar to the top of the screen then release the mouse button
One of these methods should toggle between full screen and where it is now
Or - Hover your mouse over a corner or edge of the troublesome window until the cursor becomes a double ended arrow - Then click and drag to re-size the window - Then click and drag the title bar to get the full window back in view
Jan 02, 2017 | Computers & Internet
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Acer tablet troubleshooting
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
How do i get my computer out of the resolution mode?
Apparently the monitor screen resolution setting is not correct. Screen resolution stays up until it is corrected.
Either the setting is off in Windows, or you have been changing the monitor settings, with the monitor.
WinXP:
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Go down to where it states Screen Resolution.
What is the pixel setting? For example mine states 1600 x 900 pixels.
I am running dual monitors, and this is the correct screen resolution for the Primary monitor.
If it wasn't I would Left-click on the Slider, hold the left mouse button down, and slide the Slider to the correct native resolution.
(Under Screen Resolution is a line. To the left it states - Less
To the right of the line it states - More
The Slider is the rectangular down arrow on the line )
ALSO;
Under the Color quality heading, make sure in the box under it, that it states - Highest (32 bit)
IF not, left-click on the blue down arrow to the right.
Then left-click right on - Highest (32 bit)
How to know what is the native resolution for your monitor?
Look at the manufacturer name, and the model number on the back.
Type this information in your browser search bar, then click on the search icon.
Look for Specifications.
If you changed the screen resolution settings with the monitor, press the Menu button. The screen should go off.
ALSO, with a new monitor there is an Installation CD Disk, provided with it.
This disk MUST be used. It has the drivers for the monitor on it.
[ Drivers: Small pieces of software that allow the Operating System to 'communicate' with a device.
The monitor is a Device.
Windows XP, and Windows 7 are two examples of an O/S.
Operating System ]
If you have Vista or Windows 7, post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 11, 2012 | Dell Computers & Internet
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
383 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
