Question about Maytag UMV1152 Microwave Oven
Micro wave makes a buzzing noise and doesn't heat.
    President:
  • 1,561 Answers
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken and never let the microwave oven heat unless it is replace and this is not easily fixed because you will need to disassemble the microwave oven to fix it ;i advice you contact a service technician to help replace the broken electronic module(magnetron).
Take care.
Posted on Jun 05, 2010
GE spacemaker GL1800 runs but does not heat
For that sound it will need atechnician but for not heating you cqn replace fuses
Sep 13, 2014 | GE SpaceMaker Microwave Ovens
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Micro wave will not heat up. there is no buzzing noise.
More than likely it's the magnetron and/or diode, chances are it may still be under warranty. Online owners manual states 5 year warranty on magnetron. Part only, service call and installation not included. Diode not covered. They require serial number, and will let you know if it's still under warranty. Installation appears to be simple, UNPLUG MICROWAVE THEN MAKE SURE YOU DISCHARGE CAPACITOR. INJURY OR POSSIBLE DEATH IF NOT DISCHARGED PROPERLY. Google how to install magnetron and discharge capacitor. It will save you approx $ 250 - 300 doing it yourself. Hope this helps. Be Safe
Dec 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire PLMV168K2 micro wave stopped heating food. Still has turntable and light functions. Seems to have more of a power load after initial start. The buzz is more intense than normal.
A loud buzz is a symptom of a shorted magnetron or high voltage diode. Would recommend that you take it to a qualified repair facility if you want it repaired, but if the magnetron has failed, the part costs can equal that of a new oven.
Dec 06, 2010 | Frigidaire PLMV168 Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Hotpoint micro wave makes funny noise and doesn't heat up food
Check door switches ... particularly if you are guilty of opening the door while the oven is in operation (door safety switches are probably cooked ... no pun intended)
Let me know if you need more help
a
Oct 07, 2009 | Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
Buzzing Microwave
the buzzing is the magnatron tube juicing too thousands of volts before emmitting the micro-wave radiation to what your cooking that turns molecules 180 degrees around... guess that friction is what really heats it.
radar ovens is what they use to call em and even people would stand in front of big ones to warm up long ago...lol canibles will love that.
Jan 11, 2008 | Panasonic NN-T990SA Microwave Oven
Maytag UMV1152 Microwave Oven Logo
64 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
