Question about Goodman CLQ36AR49 Air Conditioner
My AC does not cool down
My Ac is not cooling down and when it stops working the drain iside the fan is all frosted
    Scholar:
  • 45 Answers
Can you see the A-Coil that the drain is coming out of? First, make sure you have a clean filter in the furnace so there is less air restriction. If the A-Coil that is sitting on top of your furnace looks like a block of ice, you may have either a blockage of air trying to pass over the coil. That could be dirt plugging the underside of the A-Coil. More than likely it is you are low on refrigerant causing the refrigerant to flash before it hits the coil thus freezing the condensate that is building on the coil. Call your local certified HVAC repair man to take a look at it. Let me know how it goes.
Posted on Jun 05, 2010
The engine Temp gauge got real close to "H"but went down soon as i got rolling.Also engine cooling fans not coming on. even when i engaged AC. the fans are electric. . .?
The reason that you drive and engine cools down is that cool wind is blowing in the grille in front of the car and when you stop, that natural wind stops cooling it down.
First check the fan fuse. If it is OK check the fan itself: just apply wires on the connector of the fan and attache it to the battery (dont mix "+" and "-") If fan will not start, replace the fan motor. If it starts check for the Fan Motor Relay
Oct 27, 2015 | 2008 Ford Escape
It cools great when first turned on. After so many hours of cooling it stops cooling
Have you checked up in filter area at ceiling to see if fins are frozen or frosted bad? If they are dirty, they can cause frost/ice and AC goes in to fan only until frost/ice is gone. When did unit actually get a good cleaning last? Too many registers closed or blocked can cause freeze up as well. Does this unit have ducted or non-ducted system?
Aug 18, 2013 | Dometic Rooftop RV Air Conditioner
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
Ford focus 2006 engine overheating once ac swicth is on..
CHECK TO SEE IF COOLING FAN IS RUNNING.IF NO CHECK COOLING FAN FUSE AND RELAY.THE COOLING FAN NEED TO BE RUNNING WHEN AC ON BECAUSE AIR CONDITIONER PUT A LOAD ON ENGINE.COOLING FAN KEEP RADIATOR AND AC CONDENSOR COOL.FAN NEED TO RUNNING.
Sep 04, 2011 | Ford Focus Cars & Trucks
Does not cool coils frost up in front
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
May 28, 2010 | Fedders X Chassis A6X06F2A Air Conditioner
Mercedes benz airconditioning
You might check the cooling fans on the condenser to see if they are running when the ac is on.If they are not check for blown fuse,or bad cooling fan relay.Do you notice if the ac cools better when running constantly,and the ac is not so cool when in traffic,stopping and going,and running slow?If so the cooling fan,or fans are not working.If the fan fuse and the relays check out fine,then replace the fan,or fans.If I can help any more please ask.roniecon@gmail.com
Aug 19, 2009 | 2004 Mercedes-Benz C-Class
Air won't cool when the car is stopped on a 2004 chevy cavalier. car temp is normal
make sure electric coolant fan is running.if not check or replace fan relay.the coolant fan has to be running to cool down refrigerant in condensor.so refrigerant in condensor is cooled back down to high pressure liquid so it can go to evaporator.see ifcoolant fan not working.the AC is not going to cool.when you driving the condensor is cooling down from moving air when car is going.when you come to a stop.cooling fan suppose to be on so condensor gased can be cooled down.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Jun 22, 2009 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
106 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
