Question about Acoustic Solutions M 100 Main / Stereo Speaker
How do i access hdmi 2 on my lcd32761hdf tv. i have cable (virgin) in hdmi1, dvd in ext 1 & the wii in ext 2. i now have a ps3 i would like to set up.
  • wolfies_nuth Jun 05, 2010
    but i have plugged the ps3 into the hdmi 2 plug on the back of the tv?? i just dont know how to gwt the picture on?
  • 11,800 Answers
You can't access it simply because it doesn't exist - your tv has only one HDMI jack.
Your only option is to use a HDMI switch, one like
http://www.amazon.com/HM-501-5-PORT-HDMI-control-cable/dp/B000FHQMFK
Posted on Jun 05, 2010
  • Azrael SRL Jun 05, 2010
    As you can see here
    http://www.ciao.co.uk/Productinformation...
    As you can see here
     the Acoustic Solutions LCD32761HDF tv has only one HDMI input. You either have a different model of tv or that is not an HDMI entry.
    What you have 2 of them are SCART connectors, which btw you can use to connect a PS3 with a special cable.
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
Ps3 is in hdmi1 and direct tv and wii has to share the video input because my tv doesn't have enough outlets so I have to switch cables every time . How can I get the wii to work ?
What you could do is setup the PS3 to HDMI-1, DirectTV to HDMI-2(or whatever compatable) and setup the Wii to either a component cable(RGBWR) or a Composite cable (YWR).
I'm not sure you can support all 3 systems through 1 HDMI cable, Not unless there is a tree cable that you have to all three. And even then only one could be on at a time.
Nov 27, 2012 | Video Game Consoles & Games
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
We have a Polaroid 4241-TLXB television. This evening we turned on the TV and the Video6 (HDMI1) is not accepting sound. The picture is fine when that input is selected. We had our STB attached to HDMI1...
I am having a somewhat similar experience. The HDMI 2 is a little flaky on these TVs, try turning the input device that is attached to HDMI 1 OFF then reboot the TV. For some reason, if there is a signal going to both HDMI inputs at the same time there are major problems. I also found that if I input L/R audio into the HDMI 2 analog jacks, that sound also goes to HDMI 1(if no digital sound signal is going there).
Feb 16, 2011 | Televison & Video
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
When connecting motorola dct6412 to samsung tv, blu-ray player & avr via HDMI (DVI), do you run the HDMI from dvd & cable box to the avr, then seperate HDMI to the tv?
If you have more than one HDMI port on your TV,
run one HDMI cable from the DCT6412 to the TV,
and one HDMI cable from the BluRay unit to the TV.
Then, use the "source" (or "input") control on the TV's remote-control to select either 'HDMI1' or 'HDMI2'.
Dec 16, 2009 | Motorola Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Nov 16, 2008 | Onkyo TX-SR606 Receiver
Acoustic Solutions M 100 Main / Stereo Speaker Logo
298 people viewed this question
Top Acoustic Solutions Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Acoustic Solutions Audio Player and Recorder Expert? Answer questions, earn points and help others
