Sharp tv problems
I can't get my tv to turn on,resistors in the power cercuit just getting hot
  • 54 Answers
Maybe you are a technician you will open your tv set thats why you know that the resistor geting hot. can you figure out witch resistor get hot? The value and wattage. Or tell me the no./color coding.More info.
Posted on Apr 11, 2008
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a · Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Dec 28, 2015 | Sharp Televison & Video
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Should i change a burned resistor for a better one?
It sounds like you have other problems that're causing that resistor to get too hot, Angie. Carefully check for any other components that are also getting hot when that resistor gets hot.
Aug 11, 2014 | Philips 42PFL5603D/F7 LCD TV
Sharp TV. over heating resister near power supply
If the wattage rating is less it will definitely go hot. Resistor overheating may be due to leaky capacitors also. If input voltage is higher also this could happen. If the performance of the TV is fine not to worry.
If smoke comes from the resitor, you have to be alert. If you find the TV performance is OK , you can increase the wattage of the resistor, keeping the same resistor value.
Do not flush mount the resistor to the PCB. Mount it at a higher level and solder.
Sep 03, 2010 | Sharp Televison & Video
Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I need to replace a cercuit board in a sharp Aquos TV. Where can I order the part ?
I order lots of boards from Discount-Merchant.com, they have very cheap prices, the only bad thing is that the warranty is offer only to service centers
Jun 25, 2009 | Sharp Aquos LC-20E1U 20 in. LCD Television
Wierd problem
Here is something that I found that might help?
http://www.netnoise.com/boycott_rca/rcabook2007-8.html
Sep 15, 2007 | RCA 27F534T TV
Ser,#b5320688126303
bad electrolytic capacitors in the power supply or open resistor in the power supply startup circuit. I had this problem of 220k ohm 1/8w r1 in a sharp 20"lcd. This resistor is connected to + of the main bridge through a power diode. Tim Rasch
Aug 24, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Sharp 27N-S300 TV problems
This could be several things, but most likely a burned loose resistor or bad solder joint. All of which causes an inoperative power supply with the result of having a "dead" set. It would have to be checked out to find the problem. Stargazer
Jan 11, 2007 | Sharp 27N-S300 TV
Re:tv
Hi Redd, You might have better luck posting this under Sharp TVs: http://www.fixya.com/support/sharp/standard_televisions The black lines at the top of the screen are usually an indication of a problem with the vertical output section. It's often bad electrolytic capacitors, the vertical IC, or both. That's apparently not a US model, so it will be hard to find the values but you could contact Sharp Philippines: SHARP (PHILS.) CORPORATION [Philippines] Km.23 West Service Road, South Superhighway, Alabang, Muntinlupa,Metro Manila, Philippines Tel: 63-2-842-1371 Fax: 63-2-842-0530 Service Center Tel: 63-2-807-4991/4992 Fax: 63-2-807-0388 Home Page: http://www.sharp.ph/ Good luck.
Dec 19, 2006 | Sharp R-930AK Convection/Microwave Oven
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
