Question about Roper REX4634KQ Electric Dryer
Roper dryer model rex463kq1 does not produce heat, heating element replaced,changed sensor. no response. any ideas?
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
jsrock516
  • 5911 Answers
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Posted on Sep 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Posted on Jul 25, 2009
aasc
  • 1606 Answers
SOURCE: MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Posted on Aug 02, 2010
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
My roper red4640yq1 stopped heating up...we found the heating unit was bad do replaced it..still no heat up...have replaced every thermostat and the sensor still not heating and the timer isn't advancing. ...
If heating element and all thermostats / fuses have been replaced, that leaves power source, timer, and motor as possibilities. I would check breaker that it's notvtripped half way. If not that and 220 v is going to unit, then it's most likely timer.
Sep 15, 2017 | Roper Dryers
I have a Roper RED4640YQ1 dryer and it will not advance to the cool down cycle on any setting. The dryer completely shuts off as if the cycle was over. I've replaced the thermal fuse, nothing changed.
Not familiar with the Roper unit but most dryers have TWO thermal sensors.
One to keep check of the Drum temperature and one in the coil chambers to regulate the coil temperature
Jun 05, 2015 | Roper Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
The dryer no longer produces heat
you will most likely need to replace the heating element, go to www.repairclinic.com and buy the part, they can also provide the instructions to replace the heating element
May 23, 2010 | Roper REX4634KQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
69 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
