Question about Whirlpool Duet GHW9150P Front Load Washer
I followed the tips for the f02 code, cleaned hoses and filter and it didnt fix it. ordered a new pump online and it came in with one of the four impellers broken leaving only 3. I installed it ran spin cycle and it completed, so I loaded it with clothes and started and got the sud code and then f02 again. Is it because the 3 blades wont empty the water or something else. clothes are piling up!!!!
  • Oloyede Monsuru Jun 05, 2010
    hello, The F02 is an error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F) There is a chance that there is a loose wire
    connection on the water temperature after you have carry out your home work (clean up).make sure that all wire are well connected to their positions. Good lock and thanks for using fixya.
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@#@#@#
Posted on Sep 29, 2010
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
What does F02 code on duet washer mean?
Jul 28, 2014 | Whirlpool duet Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hello My Maytag black front loader washer is displaying an error code of F02. Do you know a fix for this error code? Thank you
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Maytag Washing Machines
A code F02 appears on the display and also SUB. What does this mean? And how can I fix it, since this problem pauses the washer as well?
(Tip Courtesy JSRock)
Thanks for using FixYa!!
Dec 10, 2010 | Washing Machines
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
Sep 27, 2009 | Kenmore Washing Machines
F02 with good pump and clear filter... now what?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^%#$
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
