Question about Sony KDF-50E2000 50" HDTV
I was watching tv, then it shut off.Everytime i swiched back on it would shut off and red led lamp light came on. So i pulled up manual online and pulled lamp housing out gently and bulb does not seem to be bad.Filament is still in place. so i replaced lamp housing gently, now the power led light comes on and blinks red 3 times.What could possibly be going on with tv(kdf-50e2000)
  • 3 more comments
  • bob647al Jun 05, 2010
    I was watching tv on my Kdf-50e2000 lcd.Then tv turned off.I kept trying to turn tv back on,but it kept switching off. Then lamp light led came on. So i did some research online and looked at manual for this make and model. It said my lamp is probably bad.So i gently pulled out lamp housing and visiually inspected bulb,the filament did not seem broken.So i then put housing back in and closed all doors securely on tv. Then now i keep getting 3 red flashing lights on led power light. If this is just a bulb issue and it is blown then i will just replace,but the power led light is still flashing red 3 times.
  • bob647al Jun 06, 2010
    I have taken back panel off and see the switch i think you are talking about,it has almost like a spring mechanism where the lamp door cover goes.that is seated all the way and tv still has power light led blinking 3 times and tv will not turn on.please help.
    yeah i see the switch on board and the circuit is being completely closed by lamp panel door. but i will pull lamp again and reinsert and see if that works.
    Ok no more 3 red blinks on power light, but now the tv goes thru its start up and lamp light comes on.But the bulb looks fine. filament is not broken and there are no pieces of glass in lamp housing. so what could be problem with lamp.
    No havent replaced lamp. can u suggest a place in tucson az or online that is reasonable.
  • 10,594 Answers
3 times red power light blinking shows that lamp cover is not fixed properly.
Please make sure that lamp cover is placed back in its position securely because lamp cover engages a safety switch inside that sends signal to system control chip that lamp and cover is secure.
Regarding tv shuts off problem, it would be due to weak lamp.
How old is this tv and did you replaced its lamp in last 2-3 years?
Let me know to solve your tv problem.
Thanks.
Posted on Jun 05, 2010
  • 19 more comments
    The lamp housing and Cover is seated firmly. You can not close lamp cover door if it does not line up with grooves in tv,so that lever can turn all the way to close position.The tv was manufactured in 2006.And the lamp has never been replaced.The lamp looks fine.
  • Shahid Electronics
    Shahid Electronics Jun 05, 2010
    Get back to you shortly with related exploded view image.
    Thanks for waiting.
    Below images taken from service manual to clear my point.
    First image shows lamp and lamp door.
    Second image shows lamp cover that is plastic cover, the first part that was removed to pull out lamp.
    Hope this will give you better idea.
    Thanks.
    Image-1
    Image-2
    Make sure plastic cover is also seated firmly then turn On tv.
    Ok it looks exactly like that,but i was not putting other door back on.I did not know that their may be a mechanism on that part not allowing tv to turn on.Hold on i will check it now.
    OK, take your time.
    Lamp assembly engages one switch and plastic cover also engages another safety switch.
    Everything has been put back correctly and the power light is still flashing red 3 times.
    OK, that means plastic cover safety switch got broken, take off lower back and inspect that switch.
    There is no other reason for 3 times power light blinking.
    can you elaborate a little bit more.
    Plastic lamp cover notch press one safety switch that seems broken for some reason and causing problem. It is mounted on lamp housing and can only be seen if you take off lower back of tv and check nearby lamp cover area.
    Ok, no problem.
    If switch found broken, let me know to provide you part number and where to buy.
    Can you please send me a pic of where this panel is,because it looks like the whole entire back panel has to be taken off in order to find this switch.
    OK, I will send you picture after 20 minutes.
    Thank you, you have been very helpfull. When i think i have found problem i will accept solution. The other tech was being rather rude. I am more than capable to fix the problem i am just seeking a lil assistance
    Thanks Dave
    Can this switch just go bad,because tv was fine for the past week since my girlfriend moved it from her place to mine and it did not fall or get bumped.And why would lamp light come on first and then now power led?
    That is tinny switch that often got damage while fixing lamp cover.
    Posting helpful image in next response.
    OK, below is an image shows how many screws need to be removed to take off lower back of tv. No need to remove upper big part of back removal.
    Near lamp housing, you will see T2 circuit board (its small green board) and safety switch is mounted on that board that would be broken and causing problem of 3 times blinking red light.
    How was other expert that you said is rude?
    Thanks.
    I will check it once i return home. But why would this start after a week or so of watching and lamp light came on first.I will take apart later
    Thank You
    Shahid Electronics Jun 06, 2010
    OK, please take out lamp and reinstall it as lamp assembly also push one switch and lamp cover push another switch that is mounted on T2 board.
    3 times light blinking is only related with these two switches and just to make sure that lamp is inside tv.
    DLP lamp has limited life span like 3000 working hours, after that time it consume more current than its rating to produce light. DLP lamp is not usual house bulb that has filament, it has 2 electrodes and spark of high voltage between these electrodes produce light and heat as well.
    Now once lamp start consuming more current that means it can now damage its high voltage source (ballast supply) that times protection activates and tv shows lamp light warning, that means time to replace lamp for next 3000 working hours.
    Did you replaced the lamp in last 2-3 years?
    I would recommend to buy Sony original lamp from Sony Accessories Store and required lamp is F93087500
    LAMP BLOCK ASSY XL-2400 available for $200
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 3 blinks is a lamp door error which means that either you did close the lamp door properly and/or the lamp is not seated properly in the TV. To start with take the lamp out and then insert it back, it doesn’t seems to be a bad lamp so you’ll need to check the lamp door switch which might have gone bad. This can also happen if the lamp door switch is just loose, so you can also take the lamp cover off from the back then take the lamp out and try to reset the lamp door switch and then put the lamp back in. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 6 more comments
    I have done all of this a few times and power led is still flashing 3 times but tv will not turn on. another tech told me to take off lower back cover.
  • Rylee Smith
    Rylee Smith Jun 05, 2010
    As I said it is the lamp door switch that should be replaced to resolve this issue so can even try to jump start it with the switch removed which will tell you that it is the door switch that has gone bad or something else. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    How would i go about jump starting the switch and what does the other tech mean about taking cover off.Looks like the whole back tv cover would have to come off.
  • Rylee Smith
    Yes right if you are not sure what needs to be done then its better to get it checked by a tech. to avoid any future issues.
    Not the Answer i was looking for, and i am more than capable to fix myself am just asking for a lil assistance.
    Bye
  • Rylee Smith
    As I said this is a lamp switch error which means you have to keep on trying to reseat the lamp until it goes away or try to reset the lamp door switch. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Jun 06, 2010
    Thanks
    Rylee
  • Rylee Smith
    Okay, please post back for further assistance.
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
Jun 13, 2008 | Toshiba 50HM66 52" Television
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Sony KDF-50E2000 50" HDTV Logo
295 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
