Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
Hayward 1 hp pump clicks then shuts off - Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
My hayward 2 speed pump went out the pool guy said a 1 speed is all I need. Is this true can he just put a one speed in place of my 2 speed.
Posted on Aug 20, 2011
    Scholar:
  • 78 Answers
If it has an internal centrifugal switch, usually under the cover at the rear of the pump, it might be stuck. Check it got movement. The weights on the switch move out away from the shaft when starting. If that is ok, possible capacitor.
Posted on Jun 06, 2010
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: new hayward 1 HP super pump runs 1 or 2 seconds,
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Posted on Jul 04, 2009
  • 93 Answers
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Posted on Jun 07, 2009
MOTORWIZJ
  • 1368 Answers
SOURCE: turn breaker on to hayward
DIRTY START SWITCH OR AND COULD BE THE START CAPACITOR OR RUN CAPACITOR,. RUN CAPACITOR IS ON TOP OF THE MOTOR. I WOULD SUGGEST YOU TAKE THE BOLTS OUT AS PICTURED AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING.. SEARCH YOUR AREA FOR HIM ..JAY LONGWOOD FLORIDA
Posted on Sep 30, 2011
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
Turn breaker on to hayward pump 1 1/2 hp model C48L2N134B1 just heard a humming noise and shut off
May 22, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Just wired Hayward super pump 1 hp and it ran great for maybe 1 minute. It then began making a series of clicking noises; but, I shut if off before worsening the problem...Please help anybody. What could...
better check the power coming into the pump. Is it 240 or 120?
Double check that you have the correct setting on the motor for whichever amount of power your feeding it.
Is it a brand new pump? If its brand new and you do in fact ave it wired correctly, id return it
Aug 14, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
New hayward 1 HP super pump runs 1 or 2 seconds, then shuts off. After 1 or 2 minutes, will come on for 1 or 2 seconds, then shuts off again
Jul 04, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward 1 hp super Pump just hums then shuts off.This is an inground pool
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
633 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
