Question about Husqvarna Designer I
When i touch the scissors icon to tie off the stitch the machine cuts the threads but I cannot then continue to sew because the bobbin thread does not reset itself . I have to re-thread the bobbin each time to continue to sew.
  • 135 Answers
Have you taken out the bottom bobbin parts and cleaned out the lint from there? That is probably all you need to do.
Posted on Jun 24, 2010
When finish sewing a line, the thread cutter doesn't cut thread and when I try to remove my work it's very tight to the plate and I have to force out to remove it.
Unthread the machine. Remove the stitch plates and clean out any lint and loose threads. Also clean any lint from the top of the machine. Unless it is a non oil machine use a little sewing machine oil on moving joints. Give the machine a new needle. Carefully thread and insert the bobbin. If this doesn't help you might need to take the machine for repair.
Jul 02, 2017 | Sewing Machines
Can anyone help me with an idiots guide on engaging the bottom bobbin
Are you asking how to pull the bobbin thread up? Simply hold the thread tail from the top thread and gently handrotate the handwheel toward you. One full circle completes one stitch cycle. The upper thread should hook the bobbin thread and pull up a loop. When that loop appears above the needle plate, gently pull the upper thread tail, enlarging the bobbin thread loop and catch it with a sewing tweezer, pin, or even the point of a scissor blade to pull the rest of the bobbin thread to the top.
How and Why to Bring up the Bobbin Thread
Nov 13, 2015 | Sewing Machines
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
Feb 24, 2011 | Elna Sewing Machines
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
Take out the thread. Now cut the end of thread using a pair scissors. Now try that again. Once i had the same problem and later found out that the uneven end of the thread caused problem by refusig to move around freely hence preventing the stich formation
Dec 02, 2010 | Janome Sewing Machines
How to thread the bobin on a elna air electronic su. where do i put the loose end when threading the bobin
I assume you mean when you wind a bobbin full of thread??
You take the end of thread from your spool through the tension device or an eyelet on top of the machine, then back to the bobbin on the bobbin winder and thread the loose end through a top hole on the bobbin. Click the bobbin in against the stop and press on the pressure foot to start to wind. Hold the top thread for a bit as the bobbin starts to fill and then once it has been covered by a row or two of thread, stop and cut of the loose end from top of the bobbin. Now continue to wind the bobbin until it cuts out as it fills against the stopper. Nudge the thread with a finger tip as it spools onto the bobbin to help get the bobbin filled top and bottom and not just in the middle. (bit like when you coil the garden hose onto the reel, it always wants to go in the middile only and then jams up LOL).
Also a really good idea to place your scissors handle into the top of the thread spool to slow/control it as the thread reels off it. This helps give an even tension on the thread going onto the bobbin which really helps with stitch quality later.
Jan 18, 2010 | Elna 8007
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
How do I insert the bobbin into an Elna Lotus sewing machine (the old Lotus with flip sides)
Elna bobbins have holes on the top, so wind the bobbin with the holes on the top too. The Lotus bobbin winder doesn't have a tension device, thread just goes through an eyelet. So, place your scissors curved handle on top of your thread spool as it unwinds the thread to ensure the thread then winds onto your bobbin evenly. Also watch the bobbin fill and give the thread a nudge with your finger tip to fill top and bottom as well as the middle part, you want it to wind evenly across the full width of the bobbin. When full, pop bobbin winder back to left, cut thread and pull off the bobbin.
Then place the bobbin into the bobbin holder with the holes on top, and pull the loose thread tail around anti clockwise into the tension device and gently "click" it into the tension spring with the tip of your finger while holding the bobbin still with your other index finger.
You will be able to tell if it is in tension if you then pull the thread and it doesn't come out of the tension spring. It should feel firm with resistance but still release thread to a gentle pull. tally_girl_6.jpg Now thread the top down to the needle and holding the end of the needle thread, hand wind the fly wheel towards you to lower the needle and pull up the bobbin thread. Close the bobbin cover.
Always hold the two thread tails at the back of the sewing area as you start stitching a seam until you have stitched at least 4 or 5 stitches to avoid thread jams.
Lotus is a lovely vintage machine - there is a user group on Yahoo Elna heirlooms where you can find lots of info and pictures shared by members.
Dec 07, 2009 | Elna 8007
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    I need to thread an elna air electronic su sewing machine
    that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
    Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
    See this image.
    Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
    Aug 24, 2008 | Singer 7462 Mechanical Sewing Machine
    Sewing Machines Logo
    52 people viewed this question
    Top Husqvarna Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Tally Girl
    Tally Girl
    Wayne Fellows
    Wayne Fellows
    Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
