Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Makes a whistling sound when turned on
My DC 14 Animal Dyson makes a whistling sound when it is running- it still picks up but the noise isn't right and bothers me- what could be wrong. I just bought a new canister for it- and clean it after every use.
  • 23 Answers
Bearings in the brushroll might be siezing.
If you start snapping belts, change the brushroll.
Posted on Jul 05, 2010
Testimonial: "Thank you for the feedback!! I think it is about time to replace the brushroll anyway- it is 6 years old and has had alot of use. "
  • 10,319 Answers
Maybe because it doesn't know the words so it just plains whistles
BAD PUN I KNOW
You may have a piece of paper stuck inside the debrie chuck causing this whistle
Posted on Jun 05, 2010
Testimonial: "Thank you for the help- I don't know what the debrie thing is- but I took the brush bar off yesterday and re-aligned it and put some wd40 on it and it sounds fine now. "
Why has our dyson dc14 started to sound out a high pitched whistling noise and lift the exhaust filter breaking the lid ?
Hi there, it's Jack at Dyson.
A whistling noise from your DC14 could suggest a seal or component is out of place. I'm sure we can help trace the issue, and it may be a simple fix.
When you have your vacuum easily to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 13, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson model 26 makes whistling noise
sucked up something, turn off, take apart, get ''something'' out, put together again, try, will work
Apr 20, 2013 | Dyson Vacuums
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Why does my Dyson animal squeal on carpet
Hi, there are a number of different Dyson vacuums and they vary widely in construction. Unfortunately most models have an "animal" version so that's not helpful in identifying your particular cleaner. If you know the actual model number, I'm sure I might have some ideas of what will cause squeeling.
Off the top of my head, DC25's often have issues with "whistling HEPAs" but not usually carpet related, DC17's may exhibited brush roller noises if the belt is damaged. DC07's, 14's, 33's all have a clutch drive which sometimes fail causing "racheting" or other strange noises.
Feb 16, 2012 | Vacuums
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Whistling noise on dc25 Animal
there may be a small cut in the tube or there is something stuck restricting the suction check all hoses
Jul 23, 2010 | Dyson DC25 Vacuum
I cleaned the roller on my Dyson DC 07, and after reassembly, it makes a sound like the belt is being chewed. I took it apart a couple times, goes back together fine, but still makes the noise
Hi its Darran at Dyson.
Your machine is designed to make this ratchet noise if the brush bar is obstructed. We would recommend checking the brush bar and soleplate area and removing any blockages or hairs/threads that are wrapped around the brush bar.
Full details on these checks can be found in our Support section online at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
3,341 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
