Question about Amana ACB087R Air Conditioner
GETTING A E1 CODE ON MY AMANA ACB087R. I HAD NO BUTTON RESPONCE FOR ANY OF THE BUTTONS, I THEN UNPLUGED THE UNIT FOR ABOUT 5 MINUTES. WHEN I PLUGGED IT BACK IN IT SHOWED E1 EVEN BEFORE I TURNED IT ON
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: AMANA ACB087R, reading E1 on display and none of
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Sep 07, 2010
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    Getting an E1 error message..wont start
    1. Unplug unit. 2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off. 3. Release power button and unplug. 4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 03, 2011 | Amana ACD106R Wall/Window Air Conditioner
    AMANA ACB087R, reading E1 on display and none of the buttons work at this time. Someone please help me solve this problem. Thanks.
    heatman101
    Sep 06, 2010 | Amana Heating & Cooling
    The read out says E1 and the unit doesn't work
    http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
    heatman101
    Aug 22, 2010 | Amana ACB087R Air Conditioner
    How can I clear E1 permently from my AC
    Sharp updated the procedure for resetting the E1 code.
    1. unplug unit
    2. hold the Power button while plugging the unit back in
    3. keep holding the Power button until the unit beeps
    4. unplug unit again
    5. plug it back in and it should be good
    Here is the updated user manual
    http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
    Jul 30, 2008 | Sharp AF-S120FX Air Conditioner
    E1 error code on air conditioner
    I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
    Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
    "Cool" mode shuts off
    An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
    Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
    Amana ACB087R Air Conditioner Logo
    132 people viewed this question
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
