Resolution problems on notebook monitor
I have an old acer 5610z with vista home on it.I had it hooked up to an external projector now when I boot it there is a black area at the right hand side and a blurry 2inches on the bottom.The graphics properties state the resolution options as 800x600 and 1024x768 the widescreen resolution is supposed to be 1280x960 or something.I can't find a solution anywhere.
  • 2 more comments
  • Gradient Apr 10, 2008
    No,No I meant the monitor attached to the notebook.It's native is 1280x860r960 but not 1240x768 by any means yet in the graphics properties and the device manage the monitor is set to generic 1024x768 it used to be in 1280 is their anyway i can restore factory specs?
  • Gradient Apr 12, 2008
    No somehow I deleted the clone monitor.I can't seem to re-install it.
  • Anonymous Aug 09, 2008
    I have A IBM laptop that does not download A free trial for sac.irca pinnochle because it states that the operation system needs Resolution Support to run the program
  • marinesparks Oct 08, 2008
    acer aspire 5610z for some reason has ablack column down the right side of the screen and a slightly blury area at the bottom of the screen ,, it looks likethe screen is showing 4:3 instead of 16:9 wide screen how do i rectify this,, it was working fine last nite but when i turned it on today it had this problem
    Sergeant:
    Champion:
  • 293 Answers
Check your projector settings. it should be matching the resolution on your laptop.
Posted on Apr 10, 2008
My Netbook Acer Aspire One will not hook up to the LCD projector.
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
Hook netbook to tv with rca cables
after hooking it the TV we need to toogle to the external monitor.
Presentation or mirrored display mode
  1. Right-click an empty space on the desktop, and select Personalize .
  2. Select Display Settings
  3. When the New Display Detected dialog box appears, the images on both of the displays will be automatically mirrored.
  4. (Optional) To adjust the resolution, so that the display area of the monitors are the same size in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
The computer is now ready to display the same screen on all output devices, from monitors to projectors. Press the fn and f4 function keys at the same time to switch the image from the notebook display, to the external monitor, or to both. Extending the desktop
  3. Select the monitor representing your second display. Click the Extend the desktop onto this monitor checkbox and click OK . NOTE: To help identify your monitors, click Identify Monitors . The numbers 1 or 2 are shown on the monitor icons to help you identify them.
  4. (Optional) To adjust the resolution, in the Display Settings window, select a monitor and slide the resolution slide bar. Click OK to save the setting and exit.
  5. (Optional) To change the direction the desktop will extend (left or right to match how the displays are physically set up), select a monitor and drag it to the desired position.
Apr 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
External monitor does not work
The screen resolution for the laptop may be set too high for the monitor. Try to change it to a lower resolution to test it out.
Oct 29, 2009 | Acer Aspire One PC Notebook
Connecting to projector
The function keys are most commonly F8 and F4, but you can look for the dual monitor icon in other Function Keys. If you are using Vista, you are offered a software switch when you connect an external monitor/projector. It is a matter of clicking on icons on your desktop.
Mar 24, 2009 | Averatec 3200 Notebook
Monitor Display on TV
Try the following:
Power up the projector first. With the laptop hooked up but not powered on once projector is warming up begin booting laptop. If there is still no display once its projector is fully warmed up and laptop booted you can try using the (fn) key with the laptop monitor switching function key usually F4 which switches the display monitor to show on external, external and laptop or just laptop. If this all fails try changing resolution of laptop to something that might be more projector friendly.
Let me know how you go.
Mar 23, 2009 | Dell Inspiron 6000 Notebook
MY PRESARIO V3000 WITH WINDOWS VISTA COULD NOT DETECT EXTERNAL MONITOR/PROJECTOR
Try pressing your fn key and f4.Also right click on desktop, click nvidia control panel, make sure all external monitor or projector is hooked up,click on multiple displays,you should see a drop down menue telling you to select wich display to use. Hope this helps.
Jan 24, 2009 | Compaq Presario Notebook
Computer Screen Image too small when shown through LCD Projector
You may have to setup the EXTERNAL resoloution for a bigger picture than can generally display on the lappy's screen... there is uaually a setting for the dual display setup... Right Click desktop and click Properties, the video settings can be acessed from there... Also ensure ya have the latest most up-to-date drivers for ya lappy's Video too.
Feb 08, 2008 | Acer Aspire 5610-4648 Notebook
Acer Laptop problem with LCD Projectors
I have the same model of Acer and it worked in all of my classroom LCD with powerpoint lectures and with a SONY TV at home. Try right-clicking your screen to view the NVIDIA control panel. Configure "dual" multiple display (costumize to "dual" configuration or "forced-detect."
Jan 09, 2008 | Computers & Internet
Pictures are blurred........... HELP
Good morning!
It sounds like your LCD display is bad and needs replaced. You can verify this by hooking up an external monitor. If the display is OK on that, then you probably need to go shopping for a new (or gently used) LCD assembly.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 27, 2007 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
