Question about Toshiba 32HLC56 32 in. HD-Ready LCD Television
Video stopped working. I get audio but no picture.
Video stopped working. I get audio (sound) but no video (picture). I plugged another TV into the same cable box and it works fine, so the problem is definitely the TV and not the input. Also tried other inputs (DVD, Wii) and did not get picture.
    Problem Solver:
  • 5 Answers
Sounds like the tubes may have went out.
Posted on Jun 05, 2010
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
Only audio works. No video. Worked fine last time. Tried new cables. Tried video 1 and 2 inputs to tv, still sounds great but no picture. T.V has no problem with video camera in either...
if the camera works, and you tried new cables.. it sounds like the problem is in your dvd player. make sure you have the video cable plugged into the correct slot on the dvd player.
Mar 01, 2010 | Oritron Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
I have sound but no pitcher from video
red, white plugs are for left and right audio..... yellow is video, your tv may not have a video plug, just speaker plugs
Jan 21, 2009 | Philips VR550 VHS VCR
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Audio/vidio plug in wont show picture on screen, only sound.
There is a broken connection inside the set at the jacks on the set. If you know how to solder and work on solid state circuits, you may be able to repair this,BUT if you dont please take to a repair shop as it should not cost much to repair this. A tV set is not a place to experiment with!
Sep 02, 2006 | Emerson EWC1902 19 in. TV/VCR Combo
Toshiba 32HLC56 32 in. HD-Ready LCD Television Logo
222 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
