Question about Olevia 227-S11 27 in. LCD TV
TV displays "no signal" with every input type we try. The only thing that works is the DVD. I even tryed it on a cable cord that was working from another TV
    Novelist:
  • 151 Answers
Hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Posted on Jun 05, 2010
No signal on vizio smart tv from RCA portable DVD player using composite cable
First try another composite cable. Those "in box" ones go bad all of the time. Hook up to another tv or with another style of cable (such as S video) and verify that all is truly working first. If these steps don't work message again.
Jan 20, 2013 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Inopeative tv
is the signal input board faulty? can you receave any signal from any source?
Is everything connected correctly?
Jul 21, 2008 | Televison & Video
I have an older sharp tv from an older sibling and the cable works, but I'm trying to connect what I believe to be an older dvd player to it. The dvd player has the 3 color cords (red yellow and white)...
Those modes you gave are for what TYPE of signal is comming in to the Cable/Antenna connector.
You need to switch from that input device to the other input device, the RCA plugs. These are often displayed as Aux or perhaps Line etc. It would help if you had the remote from the tv and were able to choose Aux or Line, or if it has TV/Video button. But if not, try channel button on the tv itself and go down below Ch 1. If using the cable remote to control TV, it may have a TV/Video button too. Maybe.
Good luck
Jun 07, 2011 | Televison & Video
The DVD player is running a movie with no picture or sound, the TV screen is showing an icon that says no signal...How do I get the movie to run with sound?
try using a different input on your tv. If possible try using a different cord to hook the dvd player to the TV. If neither solution works it sounds like a faulty dvd player.
also try using a different source on the tv like another dvd player, cable etc. etc. hopefully on the same input to make sure the tv is working properly .
Mar 03, 2011 | Dynex Televison & Video
My lg tv (had since Nov) says no signal for the tv or dvd player. How do I fix this?
Try unplugging all inputs and the power cord from the TV for 5 minutes. This will allow the main board to reset.
Next, just plug in the power plug to the TV, power up the TV, and even though there is not a source connected to the TV, check at least three inputs and see what the TV will report on the screen for each input.
Next, turn off the TV, plug in all known working devices (Cable/Antenna, DVD, Blu-Ray, Cable/Satellite box, Game, ….) with a known working cables to the TV, make sure all the devices connected to the TV are powered up and on, and now power on the TV.
Now check to see if the TV is seeing valid signal for all the inputs connected to the TV.
If your TV cannot see any signal at any of its inputs (HDMI1, HMDI2, HDMI3, AVI1, AVI2, Component1, ……), then the main board has failed and need to be replaced.
Good Luck.
May 21, 2010 | LG 32LG40 32 in. LCD HDTV
Hi! I have a used CRT TV Mod. 28PT4457/01. The TV channels behave as they should, but I cannot get any signal to the display from neither the Video (antenna cable to Video/In, Antenna cable from Video/Out...
Hi.
The only non-obvious thing to check from user level point of view is the PAL/NTSC settings on TV and devices, but if the TV is in use on the country of purchase, and if you get the same problem using different devices, then this should not be the problem.
If the TV does not display any input, and you are sure that the source/input selector button on remote is working, then the TV has a fault signal board, that on this models should be integrated on the digital board. The TV in that case must be fixed by a technician.
Try connecting the DVD directly (bypassing cable box), using a SCART that you know is working. If you cannot see the DVD display after selecting EXT1 and EXT2 , then it is a faulty signal input on TV.
Ensure that the problem are not cables.
Try also the following:
  1. Disconnect TV power cord.
  2. Disconnect DVD power cord.
  3. Connect DVD using SCART on EXT1.
  4. Connect again power cords.
  5. Turn DVD on.
  6. Turn TV on two minutes after DVD is on.
If yous still cannot watch the DVD signal, then the TV is faulty.
Regards.
G.
Feb 05, 2010 | Philips Televison & Video
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
Olevia 227-S11 27 in. LCD TV Logo
502 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
