Question about Eastman Outdoors 38068 Turkey Fryer
Where can i find replacement hose for my fryer
    Problem Solver:
  • 6 Answers
An grill or outdoor supply or LP gas supplier. Should have it.
Posted on Jun 05, 2010
Have a older 11 piece eastman outdoors fryer ptg no 90320 hose and reg assy needs replacement
try candain tire they do spares you may find what you need there or calgary bbq centre or bass pro shop
Aug 16, 2011 | Eastman Outdoors 37045 Turkey Fryer
HOW I CAN CONECTION WITH GAS CYLENDER ( 2 MACHINE )
Are you trying to hook up a gas fryer to a gas cylinder tank? If so, you hook them up with a hose. If you have natural gas, you need a gas line, and if you have a fryer on casters, you would need a quick disconnect hose instead. If it's an LP Gas fryer, then the gas hose is much smaller and cheaper. We sell all of these if you need one, at Restaurant Equipment Outlet, 888-542-5959, Cincinnati, Ohio. Thanks, Susan
May 30, 2011 | Frymaster Dean SR42G Deep Fryer
I need a replacement hose for an Eastman Outdoors turkey fryer -model 90314. I am in Saskatchewan,Canada.Where do I find parts?
I assume you need the hose/regulator assembly. If so, you can purchase one from any home center or hardware store that sells gas grills and accessories. Just take your old one with you for comparison purposes.
Apr 03, 2011 | Eastman Outdoors 37045 Turkey Fryer
How to drain oil from fryer
Most fryers have a valve right inside the front door that you can place a bottle under and drain the oil right into it...
If not then get a small diameter plastic hose from a hardware store and siphon the oil out...**** the oil up the hose till it is over the side of the fryer, then hold the vacuum and drop the hose over the side and lower then the oil level and the oil will start to siphon out...
heatman101
Sep 03, 2010 | Imperial IFS40 Deep Fryer
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
How do I attach the hose to the cast iron burner,do I just thread the brass fitting to the cast iron burner or is there something missing
Hello. Yes, the brass fitting goes on to the burner. At the other end of the hose is the valve and the larger connector for the propane tank. Enjoy your turkey! Regards, Joe
Nov 23, 2009 | Bayou Turkey Fryer Kit - 9195 Turkey Fryer
I need to purchase a new oil drainage hose
they have this replacement hose at this link for $4.95:
http://www.partstore.com/Model/De%27Longhi/DeLonghi/D882UX.aspx?SearchTerm=True
Nov 21, 2009 | DeLonghi D882UX Cool Touch Roto Deep Fryer
How to clean the bottom of the fryer?
Hi there. Probably your best bet would be to prop the rear legs up a little, to tilt it forward, and use a garden hose, and flush everything into a bucket in front of the drain. You may need warm water, to loosen the debris, or you could fill it with water, hook up the gas, and boil it, does a fine job of cleaning.
Hope that helps, and thank you.
Dec 12, 2008 | Imperial IFS40 Deep Fryer
Looking for the rubber hose and the light lamp for delonghi modle D - 689u deep fryer
Try this company
General Parts
1101 E. 13th
Kansas City , Mo.
64106
(816) 421-5400
Apr 12, 2008 | Pitco Frialator SG14 Deep Fryer
Eastman Outdoors 38068 Turkey Fryer Logo
111 people viewed this question
Top Eastman Outdoors Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Eastman Outdoors Grilling Expert? Answer questions, earn points and help others
