Question about Andis 04710 Beard Trimmer
Replacement power cord
How do I rewire my replacement cord on my Andis T-outliner trimmers. My fuse box keeps blowin out when I turn on the trimmers, I think I connected to wrong wires. Please help me because I dont have the money to buy new trimmers. I just need to know what color wires go where. THanKs
SOURCE: Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Posted on Jun 15, 2008
SOURCE: andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
Posted on Aug 30, 2008
  • 61 Answers
you should not have to send your clipper to be repaired before it is used, the maker of the product should be willing to walk you through the adjustment step by step, because the problem is the blade adjustment,why send a clipper back just to get a blade adjustment,which will take 30 days to return,and you will be out of a clipper,you will lose money in the process, it's simple call and ask how to (precisely) adjust blade, and if that dosent work for whatever reason, return the product and buy from another company, some companies have a way of making more money from you,unnessasarily, in this economy thats a sure way to loose business.
Posted on Jan 28, 2009
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
FSAhead2
  • 214 Answers
SOURCE: I have some green colored
if the shaver is working fine i would not worry about it , they use electrical grease and they also use grease on some of the internal working parts . it might be that the shaver got to hot and melted some of the grease . i would just wipe it off .
Posted on Jan 16, 2011
My andis t outliner has no power when I switch it on
Try the fuse in the plug, other than taking it apart and checking for power into the clipper you may need to send it away for clipper repairs!
Apr 22, 2014 | Andis T-Outliner Hair Trimmer
My new andis t outliner making a loud noise
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Mar 04, 2014 | Andis T-Outliner Hair Trimmer
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Can you charge the battery?
what battery? Ive had 3 Andis t-outliners and they were all corded, there wasnt a rechargable version made that im aware of...and even if there was, they are never as reliable as a clipper that runs on AC power
Aug 20, 2012 | Andis T-Outliner Hair Trimmer
My andis trimmer is not giving a very close shave. I like to have sharp line-ups. How do I fix it? I'm not sure of the model, but I'm using the website where I bought it as reference(...
This Andis model is not very good for shaving,I purchase one before didn't do the job. I recommend The Andis GTO you can have it sharpen and adjusted to shave. check out www.mannys-sharpening.com I had purchase my Andis T-outliner service and adjust for shaving. The good thing about manny's sharpening when you purchase Andis T-Outliner he will ask you how would you like your trimmer set at' for line ups or Fade cuts or Shaving set. he resharpen the blade and make sure the trimmer is adjust power and set blade and trimmer too your request. You may pay a little more but it's worth it. Oh one more thing about his service and warranty after 3 month he gives you a free sharpening and service on the Andis trimmer you purchase from him. You only paid for return shipping. I try his service and this guy is good in sharpening and repair. I hope this was help for Tim
Nov 10, 2010 | Andis Outliner II Hair Trimmer
How to keep the andis t outlines college while using
i took apart my andis t edjer trimmer and a small gold strip fell out
Sep 18, 2010 | Andis 04710 Beard Trimmer
Outliner keeps shutting off
let take look inside your trimmer make sure your power cord is disconnected before you do this.take the 2 top cover screws off, now open the cover like a book. Look at the coil, if the coil looks dark color like if it was cook, your coil is burning, these coils should look white and pink color. if this is the case you need to replace the coil. I recommend a professional for this. Their are other precaution when installing these type of coils. Try mannyssharpening.com they have 22 years in the business
Mar 07, 2010 | Andis 04603 Hair Trimmer
The clipper suddenly cut off how do i get power to the andis or do i needa new set. This set is only a year old. does anyone know where i can get instructions.
Chances are that the problem wasn't the clippers at all. Since they were on initially, maybe you tripped a circuit in the breaker box? If that wasn't it, you may have damaged your cord. I see a lot of people pulling by the cord to unplug...BAD decision. Check for frays near the end that houses the prongs, and if not there, open them up and check from in between where the hanging loop is up to near where it connects to the motor. I still have every set of andis trimmers and clippers I have ever owned.
If your afraid to open them up, go to andis.com, then click your country, then hover over professional and scroll down to trimmers. Select the outliner II, and when the next window opens, at the bottom there is a specs link. Click that and you should find a diagram of what your looking for when you open up the housing.
Oct 12, 2009 | Andis T-Outliner Hair Trimmer
Andis 04710 Beard Trimmer Logo
131 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
